[Support Guide] Making redirects work for you - troubleshooting and debugging
Last reviewed by Netlify Support in July 2025
Introduction
You’ve put blood, sweat and tears into building an incredible static site with all the bells and whistles. However, you’ve configured some redirect rules and you’ve come unstuck… they don’t appear to be working!
Ensure you’ve followed the correct guidance
Our redirects and rewrites document covers a broad range of use cases, from status codes to proxying another service and everything in between.
Ensure you’re using the correct syntax
It’s important that you’re using the correct syntax, whether you’re using a dedicated _redirects file or a netlify.toml file. All of our redirect options, and respective syntax, can be seen here.
That aside, let’s look at some common gotchas.
Single-Page Apps
If you have a single-page React, Gatsby or similar site, it is likely that most of your requests should be sent to your index.html file. This file then renders the appropriate content based on the URL, even though the single file is responsible for handling requests for most of your content. We have a guide for this.
Splats
A splat allows you to redirect traffic based on a URL’s suffix. For example:
/docs/* /blog/:splat 301
In this example, /docs/article1 would redirect to /blog/article1 and /docs/contact/form would redirect to /blog/contact/form, etc.
A splat can only be used at the end of a URL. If you’re trying to use a splat in the middle of a URL, you should take a look at placeholders instead.
Role-Based Redirects
A role-based redirect must either:
  • Use an asterisk, in order to gate access to an entire directory, e.g.
    /gatedpages/* 200! Role=admin
  • Provide an explicitly defined rule, in order to gate a single page, e.g.
    /gatedpage /gatedpage 200! Role=admin
Query String Parameters
Query strings are automatically passed to our redirect engine. To strip the query string from your redirect rule response, you should include a dummy query string in your to path, such as:
/* page=:page /:splat/:page?no-query-string 301!
Further guidance and use cases can be found in the Netlify Docs.
Internal Proxies (Netlify-to-Netlify)
Even if your sites use custom domains, ensure that you use the .netlify.app domain for any proxy rewrite between your Netlify sites, like so:
/api/* https://another-netlify-site.netlify.app/api/:splat 200
My redirects are still not working
If you think you’ve configured your redirects correctly but they’re still not working, take a look at your site’s deploy log.
In the deploy summary, we share how many rules we were able to process (denoted by the red box). If you’d like to see these processed rules, you can download a copy of your site, as-built, by clicking the icon in the blue box. In that download, you can review what _redirects or netlify.toml rules we processed.
I’m seeing 0 rules being deployed
If you’ve configured your rules but you see ‘0 redirect rules processed’ in your deploy log, this means that we did not see your _redirects or netlify.toml file(s) or they were not syntactically correct. Let’s run through some common causes for this.
Your framework may not like seeing files in your publish directory before being built
As a rule of thumb, your redirect file should live alongside your index.html file when your site is built. However, Jekyll and some React-based frameworks don’t like to see the file in your publish directory before the site is built.
Therefore, we need to update the build command to copy the _redirects file from another directory to your publish directory.
Your build command will either be found:
  • In your build settings, near the top of your build & deploy settings tab in our admin UI
  • In your netlify.toml file
[build]
command = "npm run build && cp _redirects dist/_redirects"
publish = "dist"
Any build command within netlify.toml supersedes the build command within the admin UI.
In the above examples, we are taking the _redirects file from the root of your site and copying it to the publish directory. You should retain your existing build command and append the && cp _/redirects dist/_redirects command and publish directory, ensuring you update this example with your file name and your publish directory.
Your framework may not like a file without a filetype
In these instances, you can rename _redirects to _redirects.txt and update your build command. You can find the steps for updating your build command outlined in the section above.
Your framework may not automatically include files which start with an underscore
Jekyll is one framework which will not automatically correctly manage files which start with an underscore. If you’re having trouble with Jekyll, you can add an include rule for the _redirects file in your _config.yml.
include: [_redirects]
My rules are being deployed but they’re not executing
Well, at least we can see the file! Now, it’s likely a matter of syntax and/or expectations.
Understanding shadowing
We discuss shadowing in great depth within the Netlify Docs. In short, you can add an exclamation point to your HTTP status code (e.g. 301!) to force the rule, even if the original file is present. If the page or file you are redirecting from exists, your redirect rule will not work without the exclamation point.
Order of execution
The _redirects file is read before the netlify.toml file. Thus, rules in the _redirects file will trump any rules in the netlify.toml file.
Both the _redirects file and the netlify.toml file are read from top to bottom. Therefore, more specific rules should sit at the top of your file and less specific rules should be at the bottom.
For example, a rule which redirects to /blog/article should be above any rule to /blog which should be above any rule to /*.
There is one exception to this rule. Hostname redirects (e.g. https://oldsite.com/* https://newsite.com/:splat 301!) should usually go at the top of your file.
_redirects and netlify.toml do not support fallback rules
As soon as a rule matches a file, no further rules for that file will be processed. Therefore, you should review your redirect files to ensure that there are no redundant or conflicting rules, and that the more specific redirects are above the more general ones in order (for instance, redirect for /blog/* before /*). More information can be found in the Netlify Docs.
Rules are being deployed and being executed for every context… and I don’t want them to!
This sounds like a job for context-specific rules!
Separate _redirects files for separate contexts or branches
Using the netlify.toml file, we are able to define different redirect rules for:
  • Your production side
  • Deploy previews
  • Branch deploys
  • Specific branches
To begin, you’ll need to create separate _redirects files for each context or branch where you require different rules.
This could be:
  • _redirects_en, _redirects_de and _redirects_fr,
  • _redirects_prod and _redirects_dev etc.
For each context, within the netlify.toml file, you can specify a unique build command. This build command can be appended with a command to copy your desired context-specific _redirects file in to the publish directory. The syntax would appear as follows:
[context.YOURCONTEXT]
  command = YOURBUILDCOMMAND && cp YOURCONTEXTREDIRECT PUBLISHDIR/_redirects
More information regarding deploy contexts and syntax can be found in the Netlify Docs or in this blog post around selective config per-build.
Still struggling?
At this point, we’ve covered all of the basics and some of the complexities. If you’re still struggling, I’d suggest that you check a couple of Netlify-hosted example sites for the framework you’re using. If all else fails, feel free to create a topic here in Community.
I can't make redirects happen. I have read, I have tried and it did not work
Redirect not working - Netlify recognises the rule
How to proxy POST Request in Netlify?
Redirecting to parent directory
Nuxt redirects does not work
How to remove the cached redirect file in netlify follow up
Netlify.toml [[redirects]] rules not working as expected
Redirect file not processed
Redirect working except for root
Redirect rule not works from external
404 redirects not working or conflicting
Gatsby trailing slash redirection
NextJS redirect not working for static assets
Routing issue on Netlify
Exclude a route when using wildcard *
Redirecting to another Netlify site's functions results in 502 in production
Redirects that are not case sensitive
Changes to Redirects with query string parameters are coming
Redirect only working without query params
I need some help to understand why redirects does not work as should in my react website
Redirect not fully-working in spite of following _redirects documentation
How to redirect?
301 error and multiple requests when _redirect file added
Need help with redirection
Redirect doesn't seem to be redirecting
How do I correctly get redirects working?
Redirect proxy domain/path to subdomain/path not working
Redirect all old urls to home
Trouble with query parameter in a redirect
404 per domain?
Intermittent issue with dynamic routes using Nuxt and NetlifyCMS
VueJS Route on Netlify
Preserve query parameters on redirect
Domain-level redirect in _redirects succeeds, but in netlify.toml fails with 500 error
Netlify Identity: How to redirect users to specific url after signup/login?
Redirects with parameters not working
Can't get redirects to work on a Hydrogen site
_redirects syntax to allow access to all files of a certain type?
CORS proxy works on Netlify Dev but not when deployed
Netlify proxying redirect causing duplicated headers
Redirect rule in netlify.toml format
ReactJS / Auth0 - routing with netlify causing infinite loop (single page routing)
Setting up routing fo using Sanity CLI as a static subdirectory
Redirects of gh-hosted pages to custom domain
Redirect by country issue
Having an issue with a Netlify proxy
Deployed my app and getting 404 page not found
Rewrite from a Netlify site to a NextJS site
Redirects with role not working as intended
Redirects dont work
[Support Guide] Compiled CDN Resources — start here!
Problem error 500
Redirects file _redirects not working for certain url instances despite having similar working implementations in file
Tailwind CSS is not working after deploying to Netlify
Having Issue with a redirect
Redirects with :splat broken
Broken redirect
Very simple redirect from subdomain to root domain not working
How can I redirect from one domain to another
How to add redirections for all children paths excluding parent path
Domain-level redirect not working
Netlify routing all my dynamic routes to a 404? ( NEXT.JS )
Redirect 404 errors using netlify.toml
_redirects not working when edge function exists
Issue setting up redirect
Multiple domains with single deployed app?
Correctly proxying a PHP (Wordpress) site from a subdomain to a primary domain path
Call to netlify function with port 443 in url leads to redirect response
Dynamic variable in the middle of redirects
Domain-level redirects do not work for aliases with https and wildcard
Netlify redirect shows strange behaviour
Site cannot be accessed broken link or url that doesn't exist
Configuration property "redirects" edited wrong
Question about parked domain
Redirect Domain alias to Primary domain
How to add domain forwarding (URL) records
Functions redirecting to incorrect url
Problem with Component Redirection in React. // Problema redireccion de componente con React
Another redirect question. #!
Page Not Found when using home link or details page link
I can't get my form to redirect the logged in user to another page
Domain redirects
Pre-launch landing page
Identity redirects not working
Redirection issue
Redirect API / Proxy - NOT WORKING!
Manually reload redirect rules?
Identity redirects in starter tier
Redirect with netlify.toml and nuxt ssr not work
Why is there a conflict between the Redirect component from react-router-dom
Redirects working locally but not on preview deploys or production
Netlify _redirects not working (CORs error on Apple OS only)
Pointing/ directing subdomain to url
How configure _redirects?
Routing changes when hovering visited link
Netlify.toml Redirects Not Applied Nuxt3
Rewrites not working
Issue with Redirects Not Working as Expected in Next.js 14 Site
Redirect is returning a 500 status code
Query param redirects with spaces in values
Reverse proxy with redirects is preserving query parameters on 302 response
Redirect path, without also redirecting sub-paths of said path
Role based access struggles
Redirect from facebook with functions check is click from facebook urgent
Remove trailing query string from redirected URL
Redirect don't work when you visit your site for the first time
Redirect domain alias certificate issue
Issues with redirect
Using query parameters in a redirect
Netlify.toml redirects not working
My redirect in netlify.toml not working?
Warning while parsing _redirects file
Localhost redirect
Redirects not working for second site
Redirect with query parameters not working
Redirect rules are not processed
Redirects using placeholder but the last placeholder has .html that I want to remove
Changes in _redirects
Redirects not working from outside of react website
_redirects directing a hole into my head
How do I host multiple React apps under single hostname?
Add a redirect for a URL path and all subsequent sub-paths
Proxy POST requests via netlify.toml redirects
Custom error page Next.js
Redirect url with one param to another url with a different param
Proxy File Shadowing _redirects not working. 404 on Nuxt SPA Bundle
