NextJS redirect not working for static assets
  • Site name: foodincome.netlify.app
Other similar topics I’ve checked:
Hi, I’ve converted a website to NextJS in one of my environments (specifically: dev--foodincome.netlify.app). Building and deploying works fine, but I’m getting 404 errors on static assets (i.e. /_next/static/whatever). A deploy preview of this in action can be seen here: FoodIn'come
I’ve also checked out the support guide on redirects albeit most of it doesn’t apply to my case (no _redirect file, default config on almost everything). Also as here I have asset optimization disabled.
For reference, here’s my netlify.toml:
[build]
command = "npm run build"
[context.production.environment]
  REACT_APP_BASE_URL = "https://foodincome.herokuapp.com"
[context.dev]
  publish = ".next"
[context.dev.environment]
  NEXT_PUBLIC_BASE_URL = "https://foodincome-dev.herokuapp.com"
[[plugins]]
  package = "@netlify/plugin-nextjs"
Also, my .next.config.js:
/** @type {import('next').NextConfig} */
const nextConfig = {
  reactStrictMode: true,
  compiler: {
    styledComponents: true,
module.exports = nextConfig
Relevant package versions:
  • @netlify/plugin-nextjs: ^4.2.7
  • next: ^12.1.0
Is there anything wrong with my config or is it a bug?
As an example, I see a 404 error when trying to access /_next/static/chunks/main-a054bbf31fb90f6a.js.
If there are no redirects in effect, then your build would need to be placing a file in that location for it to be deployed by Netlify and accessible.
Have you checked what your build is outputting?
Have you set your “Publish directory” (Build configuration overview | Netlify Docs) appropriately?
I have unset all settings from the Netlify UI and set everything from netlify.toml.
The published directory is right, the problem is with redirects. The netlify-next plugin does generate redirects for NextJS, but somehow they are not applied correctly (even though they seem fine).
Check out this snippet:
    [[context.dev.redirects]]
    from = "/_next/static/*"
    to = "/static/:splat"
    status = 200
Generated netlify.toml:
[functions]
  [functions._ipx]
  node_bundler = "nft"
  [functions.___netlify-handler]
  included_files = [
    ".env",
    ".env.local",
    ".env.production",
    ".env.production.local",
    ".next/server/**",
    ".next/serverless/**",
    ".next/*.json",
    ".next/BUILD_ID",
    ".next/static/chunks/webpack-middleware*.js",
    "!.next/server/**/*.js.nft.json",
    "!node_modules/next/dist/compiled/@ampproject/toolbox-optimizer/**/*",
    "!node_modules/next/dist/server/lib/squoosh/**/*.wasm",
    "!node_modules/next/dist/next-server/server/lib/squoosh/**/*.wasm",
    "!node_modules/next/dist/compiled/webpack/bundle4.js",
    "!node_modules/next/dist/compiled/webpack/bundle5.js",
    "!node_modules/next/dist/compiled/terser/bundle.min.js",
    "!node_modules/sharp/**/*"
  external_node_modules = []
  [functions.___netlify-odb-handler]
  included_files = [
    ".env",
    ".env.local",
    ".env.production",
    ".next/server/**",
    ".next/*.json",
    ".next/BUILD_ID",
[build]
  [build.environment]
  NEXT_PRIVATE_TARGET = "server"
[[plugins]]
[[redirects]]
from = "/*"
to = "/index.html"
status = 200
[[redirects]]
status = 200
[[redirects]]
from = "/_next/image*"
to = "/_ipx/w_:width,q_:quality/:url"
status = 301
  [redirects.query]
  url = ":url"
  w = ":width"
  q = ":quality"
[[redirects]]
from = "/_ipx/*"
to = "/.netlify/builders/_ipx"
status = 200
[[redirects]]
from = "/cache/*"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/server/*"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/serverless/*"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/traces"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/routes-manifest.json"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/build-manifest.json"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/prerender-manifest.json"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/react-loadable-manifest.json"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/BUILD_ID"
to = "/404.html"
status = 404
force = true
[[redirects]]
from = "/api"
to = "/.netlify/functions/___netlify-handler"
status = 200
[[redirects]]
from = "/api/*"
status = 200
[[redirects]]
from = "/_redirects"
to = "/_redirects"
status = 200
  [redirects.conditions]
  Cookie = [
    "__prerender_bypass",
    "__next_preview_data"
[[redirects]]
from = "/apple-touch-icon-114x114.png"
to = "/apple-touch-icon-114x114.png"
status = 200
  Cookie = [
[[redirects]]
from = "/apple-touch-icon-120x120.png"
to = "/apple-touch-icon-120x120.png"
status = 200
  Cookie = [
[[redirects]]
from = "/apple-touch-icon-144x144.png"
to = "/apple-touch-icon-144x144.png"
status = 200
  Cookie = [
[[redirects]]
from = "/apple-touch-icon-152x152.png"
to = "/apple-touch-icon-152x152.png"
status = 200
  Cookie = [
[[redirects]]
from = "/apple-touch-icon-57x57.png"
to = "/apple-touch-icon-57x57.png"
status = 200
  Cookie = [
[[redirects]]
from = "/apple-touch-icon-60x60.png"
to = "/apple-touch-icon-60x60.png"
status = 200
  Cookie = [
[[redirects]]
from = "/apple-touch-icon-72x72.png"
to = "/apple-touch-icon-72x72.png"
status = 200
  Cookie = [
[[redirects]]
from = "/apple-touch-icon-76x76.png"
to = "/apple-touch-icon-76x76.png"
status = 200
  Cookie = [
[[redirects]]
from = "/favicon-128.png"
to = "/favicon-128.png"
status = 200
  Cookie = [
[[redirects]]
from = "/favicon-16x16.png"
to = "/favicon-16x16.png"
status = 200
  Cookie = [
[[redirects]]
from = "/favicon-196x196.png"
to = "/favicon-196x196.png"
status = 200
  Cookie = [
[[redirects]]
from = "/favicon-32x32.png"
to = "/favicon-32x32.png"
status = 200
  Cookie = [
[[redirects]]
from = "/favicon-96x96.png"
to = "/favicon-96x96.png"
status = 200
  Cookie = [
[[redirects]]
from = "/favicon.ico"
to = "/favicon.ico"
status = 200
  Cookie = [
[[redirects]]
from = "/manifest.json"
to = "/manifest.json"
status = 200
  Cookie = [
[[redirects]]
from = "/mstile-144x144.png"
to = "/mstile-144x144.png"
status = 200
  Cookie = [
[[redirects]]
from = "/mstile-150x150.png"
to = "/mstile-150x150.png"
status = 200
  Cookie = [
[[redirects]]
from = "/mstile-310x150.png"
to = "/mstile-310x150.png"
status = 200
  Cookie = [
[[redirects]]
from = "/mstile-310x310.png"
to = "/mstile-310x310.png"
status = 200
  Cookie = [
[[redirects]]
from = "/mstile-70x70.png"
to = "/mstile-70x70.png"
status = 200
  Cookie = [
[[redirects]]
from = "/robots.txt"
to = "/robots.txt"
status = 200
  Cookie = [
[[redirects]]
from = "/icons/cloche.png"
to = "/icons/cloche.png"
status = 200
  Cookie = [
[[redirects]]
from = "/*"
status = 200
force = true
  Cookie = [
[[redirects]]
from = "/_next/data/UEwQ5WZ88jBC8RE-GhqkC/design.json"
status = 200
[[redirects]]
from = "/design"
status = 200
[[redirects]]
from = "/*"
status = 200
[context]
  [context.production]
  [context.dev]
  publish = ".next"
    [context.dev.functions]
      [context.dev.functions._ipx]
      [context.dev.functions.___netlify-handler]
      included_files = [
        ".env",
        ".env.local",
        ".env.production",
        ".next/server/**",
        ".next/*.json",
        ".next/BUILD_ID",
      [context.dev.functions.___netlify-odb-handler]
      included_files = [
        ".env",
        ".env.local",
        ".env.production",
        ".next/server/**",
        ".next/*.json",
        ".next/BUILD_ID",
    [context.dev.build]
      [context.dev.build.environment]
    status = 200
    status = 301
      [context.dev.redirects.query]
      url = ":url"
      w = ":width"
      q = ":quality"
    from = "/_ipx/*"
    status = 200
    from = "/cache/*"
    to = "/404.html"
    status = 404
    force = true
    from = "/server/*"
    to = "/404.html"
    status = 404
    force = true
    to = "/404.html"
    status = 404
    force = true
    from = "/traces"
    to = "/404.html"
    status = 404
    force = true
    to = "/404.html"
    status = 404
    force = true
    to = "/404.html"
    status = 404
    force = true
    to = "/404.html"
    status = 404
    force = true
    to = "/404.html"
    status = 404
    force = true
    from = "/BUILD_ID"
    to = "/404.html"
    status = 404
    force = true
    from = "/api"
    status = 200
    from = "/api/*"
    status = 200
    to = "/_redirects"
    status = 200
      [context.dev.redirects.conditions]
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    to = "/favicon.ico"
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    to = "/robots.txt"
    status = 200
      Cookie = [
    status = 200
      Cookie = [
    from = "/*"
    status = 200
    force = true
      Cookie = [
    status = 200
    from = "/design"
    status = 200
    from = "/*"
    status = 200
Hey there, @giovanniberti :wave:
Thanks so much for reaching out, and welcome to the Netlify Forums.
Could you please try updating to the latest version of the plugin to see if this helps address this issue? You can read more about this here: Releases · netlify/next-runtime · GitHub
I’ve tried updating to v4.3.0 but it doesn’t seem to solve the problem :frowning:
Deploy preview URL: https://623d9b28e9c29d4940833c85--foodincome.netlify.app/design
Hi @giovanniberti,
It seems you’ve an invalid redirect rule in place:
That’s what’s causing issues.
Is there any way I can delete this rule? I currently don’t have any rule in netlify.toml nor a _redirects file.
Edit: I just found in another folder a _redirects file with that rule, I’ll try deleting it and report back.
Edit 2: that was it, thanks for the support!
