Hello! Can I please get my build time extended to 45 minutes?
Credit card is on file and my site id is a2a57418-ed0f-49b8-816e-5e5b21ef4d7b
My builds are usually ~4 minutes, but I haven’t done a site build in a couple of months and my image cache was deleted. I’m digging into the pros and cons of keeping it longer and whether it’s a good idea.
Hi thanks for reaching out! Welcome to the netlify support forums. I have increased your build timeout to one hour. You will need to re-deploy to see this take effect.
Hi there! we can definitely bump your build time-out up , but you’ll need to be on the Pro tier for us to make that change - that’s a requirement that applies to everyone who wants a bigger timeout. You can upgrade to Pro easily through the Netlify UI dashboard.
If you let us know when you have upgraded, we can change the settings for you!
Hi there @litttley we can definitely bump your build time-out up , but you’ll need to be on the Pro tier for us to make that change - that’s a requirement that applies to everyone who wants a bigger timeout. You can upgrade to Pro easily through the Netlify UI dashboard.
