Hi, i am having problem with the build time 15 min max control, my app will have thousands of image to process in Gatsby so it will take a lot of time to process. I am ok to pay for the extra minutes, and i saw the post from here Deploy error: Command did not finish within the time limit - #10 by expatguideturkey.off said you can extend the build time limit up to 30 mins if provide a credit card. I would like to know how can i also do this? Is it automatic extend to 30 min if a credit card is provided?
hi there, we can definitely extend the build time limit to more than 15 minutes.
Here is what we need:
Netlify account that owns the site MUST have a credit card on file even if you are a Starter tier customer. We will check! This is because longer build times use more build minutes, and there is a chance we might need to bill you for going over the limit on build minutes
the API ID for a site that you need a longer build time for (is safe to share. Example: c113e602-ade3-494e-ad41-195f488a2942), OR the netlify site name (Example: consuming-wiles-78feg.netlify.app) or the team name (Example: someTeamName)
the new build timeout, in 15 minute increments. Example: 30min, 45min, 60min and so on)
if you give us all the info in one go, we can usually get to this pretty quickly. If we have to ask for the information, that slows us down
Have the same problem - may I ask to extend build time? I have just one team with one site, so I won’t type ID here Ideally to 1 hr, because we want to test different approaches.
BTW. Looking at this thread I have two thoughts:
I couldn’t find anything in the docs with regards to max build times.
Wouldn’t it be cool to give user possibility to extend max build time by himself? At least for paid accounts. At the end of the day we pay for those minutes anyway
Hi, @devfive. I filed a feature request for people to be able to change the default build timeout in the web app and updated the timeout for your site’s build to one hour.
If there are other questions or concerns, please let us know.
Hi, @Nerd. I did increase the build time limit for the site timing out. However, the build is completing in time and the timeout is on the post processing. This is probably because of the large number of new files (about 39k) in the deploy and the time it takes for forms detection.
I noticed this site doesn’t use our Forms feature. Since it does not, you can probably fix this by disabling the Forms detecting in the Post Processing setting, shown in the screenshot below:
