Hello Netlify Community.
I have tried to deploy gatsby site but Suddenly fails multiple times.
build is working locally but it takes long time.
check my website please
Execution timed out after 15m0s
@perry any suggestions
hi khalil, the max timeout we allow for builds is indeed 15 minutes! You may benefit from optimizing your site a bit (if you tell us more about what SSG or build process you are using, or what kind of site you have, here are some tips!)
We can manually extend your build time out, but we do need you to add a credit card we can automatically bill in case you go over in build minutes. If that is OK with you, add the card and let us know by replying here, we will check you have a card on file and can then extend the build time ![]()
@perry we had added card please increase building time while it’s free and we will pay for bill in case we goes over build minutes. thank you
can you tell me the netlify site name, please?
