Hello, can you pump the build time to 1 hours for site bd4303a8-fc65-45a9-a582-cf4066e80d4d
Thanks!
Thanks!
@kmhz, this is done.
Hello, can you please increase build timeout for site 5674171a-4549-4d70-86fd-dfd8ea27f7d5
to 60 minutes? Thanks!
Hi, thanks for reaching out. I have increased your build timeout for the site above. Please re-deploy to see this take effect.
Hi, can you increase build time to 30min for site 4f43b614-99d3-479a-bd2f-a6d646b9b2ba, Thanks!
Hiya @force4 welcome to the forums! I bumped you up to 30 minutes. Can you please re-deploy to see this take effect.
Hi, can you increase build time to 60min (1hour) for site aac67e51-df3c-40dd-8ef2-cee2fda8cafd, Thanks!
@mimotic Your build time limit is currently set to 60 minutes
Thank you very much! I need a few more minutes to complete the first build. Could you increase the time from 60 to 90 minutes?
This is done. Please check.
Hi again, could you please increase my build time to 120 minutes for the following 4 sites? Thanks!
Site id 1: 10779b20-83d5-422b-9653-7c84697cb961
Site id 2: efb46dfc-112a-46ea-95b6-764fabb78049
Site id 3: 37197fd5-1d8c-4528-a5ab-3f549e91938b
Site id 4: f071d483-10ef-49d6-829b-1b7cdcacec38
Hi there! we can definitely bump your build timeout, but you’ll need to be on the Pro tier for us to make that change - that’s a requirement that applies to everyone who wants a bigger timeout. You can upgrade to Pro easily through the Netlify UI dashboard.
If you let us know when you have upgraded, we can change the settings for you!
Hi, I have upgraded my plan. Could you please make the changes now?
Thanks!
Hi @sid.m,
Is it possible to increase the build time to 45 minutes.
This is the site name - cerulean-starburst-db293c
Site id - 910cd9d2-af22-442b-a539-ef7abd45c13a
This is done, @adishtooljet.
Hi, I believe my comment was missed. Could you please increase my build time to 120 minutes for the following 4 sites? Thanks!
Hi, I have increased your build time limit to 120 minutes. Please re-deploy to see this take effect.
Hi,
I’m having same issues as almost everyone in the thread
Kindly change the build time to 60mins in my account so we can complete our build and then in a later phase adjust our code.
Thanks
hi, for which site? please provide the site ID?
Hi, could you increase the build time of my site to 30 minutes? Thanks!
9c55dfbf-1906-44bf-a0b6-6c1d0903fed3
