DNS Verification Failed When Provisioning SSL Certificate for demontazhcenter.ru HELP
Hello Netlify Support Team,
I’m encountering an issue when trying to provision a Let’s Encrypt SSL certificate for my domain demontazhcenter on Netlify. In Domain Management, it initially says “DNS verification successful,” but whenever I click “Provision certificate”, I get “DNS verification failed.”
What I’ve done so far:
  1. My domain demontazhcenter (and subdomain www.demontazhcenter) correctly point to Netlify:
  • The apex domain (demontazhcenter) has A records pointing to Netlify IPs (75.2.60.5 and 99.83.190.102).
  • www.demontazhcenter has a CNAME record pointing to incomparable-profiterole-5088ea.netlify.app.
  1. In Netlify’s Domain Management, both domains appear, and DNS was initially verified.
  2. I’ve waited more than 2 hours (in fact, several days), and the status remains unchanged. Every attempt to provision the certificate again fails with the “DNS verification failed” message.
Symptoms:
  • Each time I click “Provision certificate” or “Retry DNS verification,” I see an error stating “We could not provision a certificate. Your DNS configuration is pointing at the Netlify servers and the changes have propagated, but DNS verification failed.”
  • According to whatsmydns.net, the DNS records are propagated correctly.
  • The domain is accessible on Netlify (without HTTPS), but Let’s Encrypt won’t issue a certificate.
What I’m looking for:
  • Assistance with a manual check or override to successfully provision a Let’s Encrypt certificate for demontazhcenter.ru / www.demontazhcenter.ru.
  • Clarification on whether I might be hitting a Let’s Encrypt rate limit or if there’s another step required on my end.
Thank you for your help! If you need any additional logs or screenshots, please let me know.
We’ve routed this request to our helpdesk, we’ll follow up via email.
I am having the exact same issue. Have I hit a Let’s Encrypt rate limit?
Please share some details about the issue.
Hello,
I believe I solved the issue. I was having issues with the SSL certificate. It must have been because I had 2 A records when I should’ve only had one pointing to Netlify’s IP- it works now.
Thank you for getting back to me,
Isabella
