f13end
July 14, 2022, 9:35pm
1
Hi there,
I’m trying to set up my custom domain but am presented with the following error:
“name is already taken, landindex.io is conflicting the ownership with other existing zones
I’ve added the TXT record to my domain’s DNS
Thanks!
f13end
July 15, 2022, 7:40am
2
Can you help me for this situation ?
Hey there, @f13end
Thanks for your patience. I just went to check the TXT file and received the following error: landindex.io not found: 3(NXDOMAIN)
Can you please add the txt record again? Additionally, can you check to make sure you have your DNS configured correctly?
Here are instructions for both of those:
Last reviewed: July 2025
Note: All options discussed in this guide assume you have already added your custom domain to your Netlify site .
Hi there! Need to get your site up and running with DNS? Start here with either Newly purchased domain or Existing domain that you’ve already used.
If you have a brand new domain purchased from a registrar such as Namecheap or GoDaddy, and you want to quickly get your DNS set up, you have two options:
External DNS - Create these tw…
Last Reviewed by Netlify Support Staff: July 2025
Are you receiving the error “another site is using this domain” when you are trying to add your production domain to your Netlify site?
Read on! This is easy to fix.
This occurs when you are trying to add a production domain that already exists on Netlify under a different account.
Do you know who might be using the domain (maybe a previous collaborator or an agency you’ve worked with in the past?), the quickest way to get this resolved is fo…
f13end
July 15, 2022, 6:15pm
4
Hi Hillary, thanks for answer this is my txt dns management area i added * https://superb-sunflower-c60076.netlify.app this section.
amelia
July 15, 2022, 8:32pm
7
Hey @f13end , we’ve taken care of this for you now. Let us know if things aren’t working as expected and we can take another look
