Problem: another site is already using this domain
My custom domain name techinfo.uz
TXT verified-for-netlify Done!
I don’t know what else to do
Name
nur.yorov//sites
NurMuhammad1988
Slug
nurmuhammad1988
Name
nur.yorov//sites
NurMuhammad1988
Slug
nurmuhammad1988
@NurMuhammad1988 You must follow this support guide:
The value for verified-for-netlify needs to be the URL to this thread, so it should be:
https://answers.netlify.com/t/problem-another-site-is-already-using-this-domain/123899
@NurMuhammad1988 What you’ve done is probably enough, but you need to note that you haven’t actually set it as verified-for-netlify which is where they’ll look:
~dig verified-for-netlify. techinfo.uz TXT https://techinfo-uz.netlify.app
~dig techinfo.uz TXT https://techinfo-uz.netlify.app === techinfo.uz
@NurMuhammad1988 I’m not sure what you mean by that post.
At this point you need to wait for a Netlify staff member to proceed.
HI @NurMuhammad1988,
Thanks for updating us. I’ve verified the TXT Record. You should be able to add the domain to your site. Let us know if you have any issues. Thanks!
The domain has been removed from the other site.
Hi @arish,
I see that the domain is on a site currently that just had the SSL certificate renewed. Could you let us know what site you’re attempting to add the domain onto? If you could provide the sitename (such as sitename.netlify.app). Thanks!
Hi @Melvin
It is arishdesign.netlify.app
The domain seems to be added to the site.
Hi hrishikesh @hrishikesh,
I have the same issue on my domain easyrug.site
I have added the “verified-for-netlify” TXT record
Thank you in advance
Kind regards
Hi @KiraTopG,
Thanks for reaching out! I’ve verified the TXT Record. I believe you should be able to use the domain now. Could you please give it another try and let us know if you are still having an issue?
Thank you Melvin, I wish a good day and journey,
Kind regards
Hi @Melvin, I have a new problem :
I want to deploy my domain schreibszene.ch to sz-hugo.netlify.app but get a 401 error.
I have added a txt record with the url of this post.
I hope you can help me resolve this.
thanks a lot in advance.
Matthias
Thank you for writing in! We’ve moved your request to our helpdesk, and we will be in touch shortly to solve your issue! @Matthias_Wiemeyer
