Greetings:
If I upgrade to the Pro plan trial and decide I do not like it can I go back to my Starter plan?
Thanks
Hi @gerbreown yes, that’s correct. If you feel as though you don’t like the pro plan you can downgrade at any time.
Thanks for your quick reply.
