Regarding Form level 1 for multi-site
Currently I am in form level 1 with one site.
I have to deploy another site with different form. Do I need to pay for form level 1 again for second form?
Hey @aung,
Forms is billed per site. So, if Form A has 200 submissions and Form B has 200 submissions, this totals 400 submissions and you will only be charged for Forms Level 1 once.
But, if Form A and Form B are on different sites, they will be billed separately.
Hope this helps!
Hi Pieparker,
Noted about separate billing.
Another question.
I’m in form level 1 but if submissions is under free tier (that is under 100), it will charge or do I need to degrade to level 0?
Hey @aung,
Good question – once you’re enrolled on to Forms Level 1, you’ll remain on Forms Level 1. This will mean that you will continue to be billed for Forms Level 1 (even if your submissions in following months under the free tier).
Support can process a downgrade if you only required Forms Level 1 for a one-off surge in responses :smile:
