Manual deploys are stuck in "Uploading" with no logs
Hi folks,
Since yesterday, I cannot manually deploy a static website (I drag & drop the build folder). It was working nicely before. It is now stuck in the “Uploading” state with no logs.
Do other people have the same issue? Do you think I did something wrong?
Here’s a screenshot of the interface as well as the deploy logs:
Have a great day!
Alexis
@Amatewasu I believe that it may be broken currently.
See:
@nathanmartin Thanks a lot for your super fast answer. Sorry I didn’t find the other thread.
It’s no problem at all.
This user indicates that you can deploy via the Netlify CLI in the meantime:
The Netlify CLI docs are here:
It’s much more “developer” than the “drag & drop” is, so your mileage may vary.
I just tested and I confirm it works nicely with the Netlify CLI. Thank you!
Hi @Amatewasu - Just an update here regarding the Drag & Drop feature. The issue impacting the Drag & Drop deployment method has been resolved! Please do attempt to deploy via Drag & Drop at your earliest convenience.
You can read more details and continue the conversation here: FIXED!: Drag & Drop Issue Status & Workaround
