How can I manually upload a large project with node_modules in it? The project is around 27 mb (including modules) and uses only HTML, CSS (tailwind) and Javascript. When i try to manually deploy it, it shows this message:
We’re having some trouble connecting you to Netlify.
This error may be caused by an ad blocker or browser extension. You can try disabling blocking on this page or running in incognito
No, deploying from git isn’t the only option. Another option is using Netlify CLI. Information about that is in the documentation I previously linked (section below deploying from git.)
We’ve implemented a fix for a pending issue that was related to this particular behaviour. Please try to upload again but be thoughtful of the limitations expressed on this Guide:
