I have used 6 out of 8 recovery codes, how to get more recovery codes? From time to time, I will need it in order to login to Netlify, not sure if I’m doing anything wrong. Is there a way to get more recovery codes? Thanks
Hi, @shafiemukhre. The only way I know to get more recovery codes is to remove 2FA and then enable it again. A new set of one-time codes will be generated if that is done.
Thank you @luke! I got a new set of recovery codes
@luke I want to disable the 2FA but I’m out of recovery codes, what to do?
Hi @shafiemukhre can you try manually generating a recovery code? User settings | Netlify Docs
