Help with Sitemap
Hello I need help on my sitemap I am using Sitemap by Netlify but when I check my website clovermist.com/sitemap.xml page not found. I need help
Hi @keeshianicole,
Thanks for reaching out! Welcome to Netlify’s Support Forums!
I’m not seeing the sitemap.xml file in the deploy log. Using the Deploy file browser, the sitemap.xml is not listed. You’ll want to include the file with the deploy.
Hello there thank you so much for your response. I’m sorry i moved my website from bolt.new to netlify. Where can i edit it? I hope that you have a tutorial or anything there, or maybe something like a cpanel where i can access the file manager to add what you want me to add? I am trying to connect it with github because it says that i can access there my files and add the plugins myself, but i can’t connect it I am seeing an error, I am not sure where i can access my files or where can i edit it to add it so i can havve the sitemap.
@keeshianicole There is no way to “edit” a site that is deployed on Netlify, (at least not in the same way you would edit files via a file manager in cpanel etc).
What you do is create a ‘new deploy’, see the answer here:
There are several ways that you can create deploys.
The Netlify documentation for it is here:
https://docs.netlify.com/site-deploys/create-deploys/
