Connection to site refused
I have deployed a react application on netlify but often when I try to access the website or the preview deploy I get ERR_CONNECTION_CLOSED
saying “The server closed the connection unexpectedly”.
Please help with the issue.
hi @jsparmani and welcome to our community!
That’s not a usual symptom on our service - could you tell me the URL you access your site at when you get these errors (something like https://yoursite.netlify.com or https://yourcustomdomain.com), so I can take a look at its config and see if I can help you figure out what is wrong?
I am seeing this as well with a new manually deployed site.
The APP-ID url is working correctly https://3347deac-3d86-419a-a40c-085f2fca0b53.netlify.com/, but the custom site name isn’t resolving https://garden-v7.netlify.com/.
The custom name was resolving correctly when the site was first created, but started to fail within a few minutes.
Hi, @austin94, the custom domain is resolving for all tested locations here:
Would it be possible for you to install dig locally? If so, the output of the following command might tell us why the DNS lookup isn’t working for you locally:
dig garden-v7.netlify.com +trace
Here are the last few lines when I test (and it works for me):
$ dig garden-v7.netlify.com +trace | tail -n 4
garden-v7.netlify.com.	20	IN	A	104.248.78.24
;; Received 66 bytes from 45.54.30.65#53(ns02.netlifydns.com) in 31 ms
That IP address above is for one of our CDN nodes near San Francisco (the closest one to me) and the DNS server that answered was one we control. I would be curious to see the output from your local system to see what it returns.
It looks the issue has resolved itself. I can now view https://garden-v7.netlify.com locally.
Here is the dig output:
; <<>> DiG 9.10.6 <<>> garden-v7.netlify.com +trace
;; global options: +cmd
.			518400	IN	NS	a.root-servers.net.
.			518400	IN	NS	b.root-servers.net.
.			518400	IN	NS	c.root-servers.net.
.			518400	IN	NS	d.root-servers.net.
.			518400	IN	NS	e.root-servers.net.
.			518400	IN	NS	f.root-servers.net.
.			518400	IN	NS	g.root-servers.net.
.			518400	IN	NS	h.root-servers.net.
.			518400	IN	NS	i.root-servers.net.
.			518400	IN	NS	j.root-servers.net.
.			518400	IN	NS	k.root-servers.net.
.			518400	IN	NS	l.root-servers.net.
.			518400	IN	NS	m.root-servers.net.
;; Received 420 bytes from 127.0.0.1#53(127.0.0.1) in 9 ms
com.			172800	IN	NS	a.gtld-servers.net.
com.			172800	IN	NS	b.gtld-servers.net.
com.			172800	IN	NS	c.gtld-servers.net.
com.			172800	IN	NS	d.gtld-servers.net.
com.			172800	IN	NS	e.gtld-servers.net.
com.			172800	IN	NS	f.gtld-servers.net.
com.			172800	IN	NS	g.gtld-servers.net.
com.			172800	IN	NS	h.gtld-servers.net.
com.			172800	IN	NS	i.gtld-servers.net.
com.			172800	IN	NS	j.gtld-servers.net.
com.			172800	IN	NS	k.gtld-servers.net.
com.			172800	IN	NS	l.gtld-servers.net.
com.			172800	IN	NS	m.gtld-servers.net.
com.			86400	IN	DS	30909 8 2 E2D3C916F6DEEAC73294E8268FB5885044A833FC5459588F4A9184CF C41A5766
com.			86400	IN	RRSIG	DS 8 1 86400 20200304050000 20200220040000 33853 . iNQCz+w0KzFRSOLDC6Om9LqGiYRu3QQLsDS8+ADaOehpMGTnYCFTPWuw b2M9etAuhQ9sUGIE4IZtS/3LwhgRMWSOx+yWcyWNk39sXi/RbUHQ50hr NfiMUQ9CjCb5Gg1qEKtxOD+qT1qI4SLlZyrwkqwW90j4izBsjrzp8WEN 2YV8qDVqzT6WRbAodOzbxlitZNWRuy//b/CwZBtz0OINfcXCdGj91hFq yiMrv+Gfgs/tPgIEkwn6loUXQhFEv4tHZlbXaX6/6poussxCPEuP/BYW fAF7114ed4R1PPP74wYdIXuVAHX3g8L3fTlcFYDvvqAlYA+lNlkzstc7 KmzfAw==
;; Received 1181 bytes from 192.203.230.10#53(e.root-servers.net) in 10 ms
netlify.com.		172800	IN	NS	dns1.p04.nsone.net.
netlify.com.		172800	IN	NS	dns2.p04.nsone.net.
netlify.com.		172800	IN	NS	dns3.p04.nsone.net.
netlify.com.		172800	IN	NS	dns4.p04.nsone.net.
netlify.com.		172800	IN	NS	ns01.netlifydns.com.
netlify.com.		172800	IN	NS	ns02.netlifydns.com.
netlify.com.		172800	IN	NS	ns03.netlifydns.com.
netlify.com.		172800	IN	NS	ns04.netlifydns.com.
CK0POJMG874LJREF7EFN8430QVIT8BSM.com. 86400 IN NSEC3 1 1 0 - CK0Q1GIN43N1ARRC9OSM6QPQR81H5M9A  NS SOA RRSIG DNSKEY NSEC3PARAM
CK0POJMG874LJREF7EFN8430QVIT8BSM.com. 86400 IN RRSIG NSEC3 8 2 86400 20200227054927 20200220043927 56311 com. A7zRR2FLhyIgXRnCDNNvgAx2rJS8Rmn1XVVobuXfiDuGSvok2VpUPFfq cSN1rspiJJxCuU1z0IP5QL6zVUroFJ6JEghztjdP+P8l0rpE28/MEJz6 XHIagMgIVeUQfmDgzvBvk8ufccBKbrMJ6CWsmtJZYIjp+5Bar5qx7Ekr +QfZbnhvW2bmnLuUxK57EhVDcdpllDVYBxxjye0EU60l5Q==
LA5ACD74Q7TDCU969L726O890292GGPA.com. 86400 IN NSEC3 1 1 0 - LA5AUQJFNLG7JC1EK63FGRAK8HJ7P78I  NS DS RRSIG
LA5ACD74Q7TDCU969L726O890292GGPA.com. 86400 IN RRSIG NSEC3 8 2 86400 20200226063702 20200219052702 56311 com. PYgOvlx7BiI5LtUccYJLtLMN0ixKdFhx1y4QnY2ugXce/Npu0mMDSjcV LTju/cZNlCmcKO+kRX8dxPTdvp+UrhAxRwZCEu1azCNRVYsxIKE+bt6e rOG6PGIFV7+3TPi0zGOmwaOzZdEKxXmfE5pam2OUr1ERYuyRY8KNrrUL 0mTh+uetOQCa1yqLLWfUTXa3/ecqyz5dD0wk0q270/gx1A==
;; Received 951 bytes from 192.43.172.30#53(i.gtld-servers.net) in 16 ms
garden-v7.netlify.com.	20	IN	A	165.227.0.164
;; Received 66 bytes from 198.51.45.4#53(dns2.p04.nsone.net) in 23 ms
This issue first came to my attention from users located in San Francisco and Copenhagen. So it was originally happening across at least 3 region nodes.
Thanks, @austin94, that dig output is exactly what I was hoping for. As it is working now, this output doesn’t show what was happening before.
I’m glad it is working now though. If this issue does happen again, the output of the same command above should show exactly where the issue is occurring and give us more information to research the issue to determine a root cause.
As always, if there are other questions, we’re happy to answer.
I am having the same issue
here is the dig output
❯ dig hungryhub-build-production.netlify.app +trace | tail -n 4        hh-server2/git/develop
; <<>> DiG 9.10.6 <<>> hungryhub-build-production.netlify.app +trace
;; Received 38 bytes from 10.1.0.1#53(10.1.0.1) in 54 ms
;; Received 38 bytes from 10.1.0.1#53(10.1.0.1) in 83 ms
❯ dig hungryhub-build-production.netlify.app +trace        hh-server2/git/develop
;; Received 38 bytes from 10.1.0.1#53(10.1.0.1) in 94 ms
;; Received 38 bytes from 10.1.0.1#53(10.1.0.1) in 64 ms
Hey there, @saiqulhaq-hh :wave:
Thanks for reaching out, and welcome to the Netlify Forums. Can you confirm when this error message started? Have you recently changed any of your build settings, DNS, etc? Additionally, could you tell me the URL you access your site at when you get these errors (something like https://yoursite.netlify.com or https://yourcustomdomain.com )?
I will share this with the Support Engineers on our team who can take a closer look.
Thanks!
our web app domain is web.hungryhub.com, we use Cloudflare
however, when I dig the original Netlify subdomain, the result is the one I shared above
I have no issues accessing web.hungryhub.com, nor hungryhub-build-production.netlify.app @saiqulhaq-hh.
A slight difference when I run the first dig command from my local machine
% dig hungryhub-build-production.netlify.app +trace | tail -n 4
hungryhub-build-production.netlify.app.	20 IN A	54.253.175.63
hungryhub-build-production.netlify.app.	20 IN A	54.206.231.79
;; Received 99 bytes from 198.51.44.1#53(dns1.p01.nsone.net) in 27 ms
and Ubuntu VM
$ dig hungryhub-build-production.netlify.app +trace | tail -n 4
;; Received 99 bytes from 2a00:edc0:6259:7:1::2#53(dns2.p01.nsone.net) in 23 ms
In you responses, the return is from 10.1.0.1 while mine are directly from nsone.net.
Possibly there is something on your network that is causing the issue.
It looks like that IP is for some private network:
 whois 10.1.0.1
% IANA WHOIS server
% for more information on IANA, visit http://www.iana.org
% This query returned 1 object
inetnum:      10.0.0.0 - 10.255.255.255
organisation: IANA - Private Use
status:       RESERVED
remarks:      Reserved for Private-Use Networks [RFC1918].Complete
remarks:      registration details for 10.0.0.0/8 are found
remarks:      iniana-ipv4-special-registry.
changed:      1995-06
source:       IANA
In other words, it does seem to be something weirdly configured with the network.
the issue has gone
10 minutes after I commented in this forum
it was around 10 minutes down time
Thanks for coming back and confirming! Glad everything is working as expected now!
Hi guys, i got the same issue, my website doesn’t appear correctly i got this error : “ERR_CONNECTION_CLOSED”.
The site was perfectly functional for a few days and during a build it stopped displaying and impossible to go back
; <<>> DiG 9.10.6 <<>> alanletrocquer.netlify.app +trace
.			12937	IN	NS	c.root-servers.net.
.			12937	IN	NS	b.root-servers.net.
.			12937	IN	NS	j.root-servers.net.
.			12937	IN	NS	k.root-servers.net.
.			12937	IN	NS	g.root-servers.net.
.			12937	IN	NS	m.root-servers.net.
.			12937	IN	NS	f.root-servers.net.
.			12937	IN	NS	e.root-servers.net.
.			12937	IN	NS	h.root-servers.net.
.			12937	IN	NS	l.root-servers.net.
.			12937	IN	NS	i.root-servers.net.
.			12937	IN	NS	a.root-servers.net.
.			12937	IN	NS	d.root-servers.net.
.			12937	IN	RRSIG	NS 8 0 518400 20230228050000 20230215040000 951 . s6CbmbfMdG4lWBbh/QZXmr5MlWTGKlgkmvdnGiiVyXRu0TGLwWYdht6m RuVQJ6sefjgskdIMJw33aYoTQy/6UpqnuXH/cMwDi6zHlNDN87MFKrxD EmglifVArOJfuC8y5e9vTU32uPiPNfHIpR+b0jaGJkjHPXsv7jFUFwq0 QJGSh4phGW/zgkWShDeKlZAEXU26q1NB7GC9Zn86ccIF7q80fwfIajRP 1TQ4axqrKDQuQu33jgnaN1B13E18AeSIxl9mE/3749aTRqzvkSGrsMp4 PpWpjVCASnUULkR2invqTnniMidcOh1RaI8jKqqiM+2mUW+e/zsZKQVt TrvwBw==
;; Received 525 bytes from 10.58.0.1#53(10.58.0.1) in 105 ms
;; connection timed out; no servers could be reached
Can someone help me please ?
It finally left as it came, after 24 hours. sorry for inconvenience
Awesome thanks for confirming your site issue is no longer a problem!
