hello, can you guys add my branch deploy url to the ssl certificate? the url is v1.dsh.booleanbean.tk
i use cloudflare dns instead of netlify and main branch works fine with ssl certificate
It looks like you’re using a wildcard custom SSL cert so you won’t need Netlify to extend the cert. The DNS is misconfigured as the CNAME is pointing to a site that appears to have been deleted.
Hope this helps!
oh, thanks for the quick response
