SSL provisioning blocks changing primary domain
hello . My Netlify site is brilliant-gumption-34c725.netlify.app. I want puafuturesrealtyph.com to be the primary domain. Its DNS already points to the site and the website loads over HTTP. The old primary domain, puafuturesrealty.com, does not point to Netlify, so DNS verification fails and SSL cannot be issued.
Setting the new domain as primary returns: “We’re provisioning a certificate for your site, you cannot change custom domains until that process completes.” Removing the old primary returns: “You cannot remove primary custom domain while domain aliases are present.”
Could a Netlify support engineer clear the stuck certificate provisioning state, set puafuturesrealtyph.com as primary, and remove puafuturesrealty.com and www.puafuturesrealty.com from this site?
