Hi,
I’m looking for help with the second form on this page:
https://gbrwsite.netlify.app/contact.html
The first one works, the second one does not. Is it generally possible to have two forms on the same page?
Thank you,
Katja
Hi,
Thank you,
Katja
hi there @katjacodes , it is technically possible to have two forms on one page, but it depends a bit on how they are implemented (do they have different names? are you using recaptcha?)
It is a good idea to verify that the first form is working correctly before adding a second one, and they MUST be distinct.
You might check this very detailed thread for more discussion and useful info:
