_redirects directing a hole into my head
Hello,
I’ve been surfing around trying to find a solution for redirecting 404s to specific netlify pages & decided the _redirects organisation is the solution.
My netlify site name is: boring-cray-8f7cfc.netlify.app
The github repro is: GitHub - AHTARazzak/personal_website: Personal website (https://alirazzak.info) coded using MEAN stack & deployed using Netlify
I am not getting an error as such as my _redirects is not working and I am not sure why.
This is the current format of my _redirects:
I have placed the file in the root, src,& public site folders.
I’ve tried looking through these topics for support but haven’t succeeded yet.
Please let me know if further details or context would be helpful!
Regards,
A
Any support would b greatly appreciated!
Hey there!
So, in your last deploy, we can see all 4 rules are processed. They’re in the right location, don’t worry!
You may want to check out our redirects debugging guide.
But, in short… because the /about page exists, your rules won’t redirect to the / page. You’ll need to change the rule to a 301!, 404! or similar. The ! makes sure the rule takes effect, even if the / page exists.
If you explain what you want to direct to, and from, we can dive in on a specific rule :slight_smile:
Hey!
Thank you heaps for the response & support. I spent the day working on the ite & trying to implement what you’ve suggested although am having a hard time.
I’m trying to achieve it so the domain AHTAR redirects to https://alirazzak.info/
additionally that a 404, 302, 302 from https://alirazzak.info/ (among other errors in the future) also redirect to https://alirazzak.info/
Hope that makes sense, if not please feel free to ask me for further context &/or clarification!
Looking forward to hearing back :slight_smile:
Hey @turnleft,
Sounds… funky? I don’t think we want to have 3 different redirect rules on the same page! :face_with_hand_over_mouth:
However, for the first one, you can configure /about / 301! if you want /about to show in the URL bar, else you can do /about / 200!
Hey @Scott
Appreciate the advice so far.
More specifically what I want from the _redirects is a solution to when I refresh on one of the routed pages (AHTAR) for example and it not give me the netlify 404 error.
I considered _redirects as a solution to this as it would mean any error messages would instead be routed to the about page but now I am wondering:
  1. If there is a better solution
  2. how I would get any 404 page to redirect to AHTAR
Hope that made my inquiry a bit more clear & I look forward to hearing back!
Hey @turnleft, so this is 404ing because of the ! in the rule. I understand what you need now and a ! is not necessary – this will force the rule, regardless of whether the page you’re looking for exists or not :slight_smile:
/* /about 404 will send your users to the /about page with a 404, if the page doesn’t exist.
Hope it helps!
