Hi all — first post here. I have a project (in-count-her) deployed at the apex domain in-count-her.com. I’ve added several subdomains as domain aliases on this same project and want each one to 301 redirect to a corresponding path on the apex.
Example I’m trying to make work:
recognize.in-count-her.com→in-count-her.com/recognize -
welcome.in-count-her.com→in-count-her.com/welcome -
(8 more subdomains following this same pattern)
What I’ve tried:
I’ve configured rules in both _redirects and netlify.toml formats. The most recent attempt uses netlify.toml with this structure:
[[redirects]]
from = "https://recognize.in-count-her.com/*"
to = "https://in-count-her.com/recognize"
status = 301
force = true
I’ve also tried the _redirects file with both URL-prefix syntax (https://recognize.in-count-her.com/*`` https://in-count-her.com/recognize` 301!) and Host-conditional syntax (/* https://in-count-her.com/recognize 301! ``Host=recognize.in-count-her.com`).
What’s working:
Deploy log shows “Post processing - redirect rules” successfully every time
DNS resolves the subdomain aliases to my Netlify project correctly
SSL is provisioned (Let’s Encrypt cert covers all aliases)
Path routing on the alias works — visiting
recognize.in-count-her.com/recognizecorrectly serves the Recognize page from the project
What’s not working:
When I visit the bare alias root (https://recognize.in-count-her.com/), I get HTTP 200 and the project’s index.html (home page) is served — instead of a 301 redirect to Recognize | In-Count-Her™ . Verified via httpstatus.io: status 200, redirects 0.
This happens regardless of which redirect format I use.
Questions:
Is this expected behavior when source and destination are both on the same project (via aliases)? My read of the docs is that
force = trueshould override default file-serving, but that’s not what I’m observing. -
Is there a known limitation where redirect rules don’t apply to bare-root requests on alias subdomains?
If this is supposed to work, what configuration step am I likely missing?
I’ve been at this for several hours and want to make sure I’m not missing something obvious before pivoting to a workaround (separate Netlify projects per subdomain).
Thanks in advance.
