- we need to know your netlify site name. Example:
gifted-antelope-58b104.netlify.app
https://cellect-partner-api-docs.netlify.app - DNS issues? Tell us the custom domain, tell us the error message! We can’t help if we don’t know your domain.
https://partner-api-docs.cellectenergy.com/ - Build problems? Link or paste the FULL build log & build settings screenshot
12:57:43 PM: Failed during stage ‘building site’: Build script returned non-zero exit code: 2 (Search results for '"non-zero exit code: 2"' - Netlify Support Forums)
12:57:40 PM: Netlify Build
12:57:40 PM: ────────────────────────────────────────────────────────────────
12:57:40 PM:
12:57:40 PM: ❯ Version
12:57:40 PM: @netlify/build 29.20.6
12:57:40 PM:
12:57:40 PM: ❯ Flags
12:57:40 PM: baseRelDir: true
12:57:40 PM: buildId: 64e3430d34dadc032268df1f
12:57:40 PM: deployId: 64e3430d34dadc032268df21
12:57:40 PM:
12:57:40 PM: ❯ Current directory
12:57:40 PM: /opt/build/repo
12:57:40 PM:
12:57:40 PM: ❯ Config file
12:57:40 PM: No config file was defined: using default values.
12:57:40 PM:
12:57:40 PM: ❯ Context
12:57:40 PM: production
12:57:40 PM:
12:57:40 PM: Build command from Netlify app
12:57:40 PM:
12:57:40 PM: $ npm run build
12:57:41 PM: > acme-api@1.0.0 build
12:57:41 PM: > redocly bundle -o dist
12:57:41 PM: bundling /opt/build/repo/openapi/openapi.yaml…
12:57:41 PM:Created a bundle for /opt/build/repo/openapi/openapi.yaml at dist.yaml 48ms.
12:57:41 PM:
12:57:41 PM: (build.command completed in 607ms)
12:57:41 PM:
12:57:43 PM: Build failed due to a user error: Build script returned non-zero exit code: 2
12:57:43 PM: Failing build: Failed to build site
12:57:43 PM: Finished processing build request in 21.289s
Thank you so much
