Problem with dns propagation - ERR_CONNECTION_TIMED_OUT
My site (https://treasureboxjapan.com) is inaccessible in several parts of the world, including Brazil, Mexico and Turkey, returning ERR_CONNECTION_TIMED_OUT or DNS failures. I’m using Netlify’s default DNS setup. The .netlify.app domain also does not load from Brazil. It works when using a VPN from other regions.
DNS propagation is inconsistent globally. See attached results from whatsmydns.net and server status checks.
i have this site working more than 1 year, this problem is happening now
Please check if there’s an issue with the Netlify edge network or CDN affecting Latin America or specific PoPs.
Thanks!
It is happening the same with me
yes, it’s really a BIG PROBLEM, everytime another country became unavailable
The CNAME records are not showing up for domains using Netlify’s DNS.
I'm having a problem with all my projects, it's opening on the computer but it's stopped on my cell phones.
Its happening the same with our projects {domain}.netlify.app not working.
yes, if it’s netlify subdomain or my domain, nothing works =/
do you know how we can call netlify support here?
=/ everytime a different country
Same problem here with all my sites
Também estou tendo problemas, meus sites estão fora do ar…
Looks like a problem with VIVO Connection, I’m not facing the same problem with Claro and other companies.
@sid.m @luke Is there any issue with Netlify Network?
yes, with Claro on my cellphone it’s ok for now, but with Vivo…. nothing
Parece que o problema principal está com a vivo amigo
voltou a funcionar… aleluia
Aqui ainda não, provavelmente está intermitente
The error still persist here
  • @hrishikesh Can you help us to understand whats going on?
