I just set up my blog opendirective.net based on the 11ty hylia template witch includes Netlify CMS.
When I first set up identity it worked but I noticed my password manager (LastPass) did not offer to save the password as usual.
Then switching to another PC and trying to log in I used the password reset and tried to enter a secure generated pasword. but this fails. Then I tried to reset again and now I do not get the reset emails, even if I uses the send option in the Netlify portal.
I assume these are Netlify Idenity issues, rather than Netlify CMS
How can I get the password reset email?
Please make the identity login dialog work with password managers. I can;t even paste into the password field which is a security issue and a cognitive accessibility barrier.
So when I look at the identiy setting it says I have 0 active users. And I can find no way to make the user active again. I can only assume the incomplete password reset made me inactive.
It’s not a bug with Identity Widget, but rather inability of password managers to work in iframes, I guess. The widget loads inside an iframe, but other than that, it does everything else that a password manager should be able to use like input type = "password".
Thanks. You might be right about the iframe, though it appeared to be a popup.
But the usual work around, to paste the password, also failed. I just got a single dot appearing and failure.
It takes extra work do disable paste so is something else going on?
For now a made up a less secure but memorable password (not polite - lol)
