Hi @claygraffix
Is the site ID correct as I’m unable to find the site?
Hi @claygraffix
Hi @amiram,
In order to increase the functions timeout limit for the site, the account will need to be on the Pro Team plan (or above).
If you upgrade to the Pro Team plan or above, please let us know and we’ll be able to increase the Functions timeout limit to 26 seconds (max time).
It’s Pro now, please check and increase the timeout to the max.
hey there, @amiram
Thanks for following up! I have increased your functions timeout limit across your account to 26s. You should see this with your next deploy.
Duh, pasted the wrong thing
It is on the Pro plan.
elegant-wing-ae0b94
023f579a-25fc-4de9-a5c0-a9a99f672e60
Thanks!
Hey there, @claygraffix
Thanks for reaching out! We have increased your functions timeout. You will see that after the next deploy.
Can I also ask for timeout increment? Site id f5c3b456-07ad-4487-8ef3-32118f90d5f3
Thank you in advance
Hey there, @Iquest
I have increased your functions timeout limit. You should see it the next time you deploy.
Thanks!
Hello, could you increase the function timeout to 26 sec for site 12f44c7c-a8e8-4f86-89a2-e1c07274708a ?
Hi @green-connector,
That’s done! Please re-deploy.
Hi can you please increase the function timeout to 26sec for site 079c5c77-bef9-41db-9b74-505e2b0053fe ?
Hello @vitor47
Thanks for reaching out. You function timeout limit is set to 26 seconds. You should see this with your next deploy.
Hi, can you please increase the function timeout to 26sec for site 9d5f2986-50ee-4864-a348-abf11f50a253?
Hey there, @Tsatsi
I have increased your functions timeout! You should see this on your next deploy.
Hello, Could you bump up our functions time out to 60 seconds? We are on the Pro plan now and getting timed out in 10 secs. The site ID is 4f6bb13b-a112-4145-a93d-3f5fa964c68a
Thanks!
hey there, @cosmicforces
I have increased your function timeout limit to 26s, which is as high as I can set them. You will see this on your next deploy!
Hi Hillary
Thanks very much! Is the max 26s due to the subscription level we have or other factors?
That’s a system-level limitation. We can’t go over 26 seconds.
Hi can you please increase the function timeout to 26sec for site 3834f5c7-d063-480d-96e6-9a96e47b16f0?
Hey there, @anteriovieira
Thanks for reaching out! I have increased your functions timeout limit for you to 26 seconds. you should see it on your next deploy!
