I found new errors on the site.
This happens both on frituur.whywaitt.com as on whywaitt-app-dev.
(whywaitt.com was last published on 21 feb and has no problems. The core code base of frituur.whywaitt and whywaitt are the same, recent changes after 21 feb are completely different)
- Site loads slow: “Waiting on cache…” or “waiting on (frituur.)whywaitt.com”.
- App loads eventually (freezes during usage) or gets stuck on its loading screen
- Browser console throws “loading chunk ${random number} failed” errors.
- NEW Error:
GET https://frituur.whywaitt.com/assets/kleuren/burgers.png net::ERR_CONNECTION_RESET 200 (EDIT: Happened during Netlify outage)
- “Site is live” is shown in the middle of the build log, way before all chunks are rendered.
- EDIT: Can’t reproduce this with Firefox, this only happens on Chromium based browsers and Safari with the most recent version. Possibly a webpack and caching problem?
- EDIT: When I catch the site freezing, and open multiple tabs they all are stuck on “waiting for cache”. This really sounds like a network problem on Netlify’s side.
12:13:31 AM: Build ready to start
12:13:33 AM: build-image version: ac716c5be7f79fe384a0f3759e8ef612cb821a37 (xenial)
12:13:33 AM: build-image tag: v3.13.0
12:13:33 AM: buildbot version: e552b142336b2b1222a93a4fd4cbed0019c77b46
12:13:33 AM: Fetching cached dependencies
12:13:34 AM: Starting to download cache of 390.1MB
12:13:43 AM: Finished downloading cache in 10.004081723s
12:13:43 AM: Starting to extract cache
12:13:57 AM: Finished extracting cache in 13.604116312s
12:13:57 AM: Finished fetching cache in 23.642010721s
12:13:57 AM: Starting to prepare the repo for build
12:13:58 AM: Preparing Git Reference refs/heads/development
12:13:59 AM: Parsing package.json dependencies
12:14:00 AM: Starting build script
12:14:00 AM: Installing dependencies
12:14:00 AM: Python version set to 2.7
12:14:00 AM: Started restoring cached node version
12:14:02 AM: Finished restoring cached node version
12:14:03 AM: v12.18.0 is already installed.
12:14:03 AM: Now using node v12.18.0 (npm v6.14.4)
12:14:03 AM: Started restoring cached build plugins
12:14:03 AM: Finished restoring cached build plugins
12:14:03 AM: Attempting ruby version 2.7.1, read from environment
12:14:04 AM: Started restoring cached ruby version
12:14:04 AM: Finished restoring cached ruby version
12:14:05 AM: Using ruby version 2.7.1
12:14:06 AM: Using PHP version 5.6
12:14:06 AM: No npm workspaces detected
12:14:06 AM: Started restoring cached node modules
12:14:06 AM: Finished restoring cached node modules
12:14:06 AM: Started restoring cached go cache
12:14:06 AM: Finished restoring cached go cache
12:14:06 AM: go version go1.14.4 linux/amd64
12:14:06 AM: Installing missing commands
12:14:06 AM: Verify run directory
12:14:08 AM:
12:14:08 AM: ────────────────────────────────────────────────────────────────
12:14:08 AM: Netlify Build
12:14:08 AM:
12:14:08 AM: ❯ Version
12:14:08 AM: @netlify/build 26.5.2
12:14:08 AM:
12:14:08 AM: ❯ Flags
12:14:08 AM: baseRelDir: true
12:14:08 AM: buildId: 624e108b05ac380008d962cc
12:14:08 AM: deployId: 624e108b05ac380008d962ce
12:14:08 AM:
12:14:08 AM: ❯ Current directory
12:14:08 AM: /opt/build/repo
12:14:08 AM:
12:14:08 AM: ❯ Config file
12:14:08 AM: /opt/build/repo/netlify.toml
12:14:08 AM:
12:14:08 AM: ❯ Context
12:14:08 AM: production
12:14:08 AM:
12:14:08 AM: 1. Build command from Netlify app
12:14:08 AM:
12:14:08 AM: $ npm run build
12:14:08 AM: > frontendClient@0.0.1 build /opt/build/repo
12:14:08 AM: > ng build
12:14:12 AM: Warning: Entry point 'ionic-angular' contains deep imports into '/opt/build/repo/node_modules/rxjs/Subject', '/opt/build/repo/node_modules/rxjs/add/operator/takeUntil'. This is probably not a problem, but may cause the compilation of entry points to be out of order.
12:14:40 AM: Generating ES5 bundles for differential loading...
12:14:42 AM: ES5 bundle generation complete.
12:14:42 AM: chunk {polyfills} polyfills-es2015.js, polyfills-es2015.js.map (polyfills) 277 kB [initial] [rendered]
12:14:42 AM: chunk {polyfills-es5} polyfills-es5.js, polyfills-es5.js.map (polyfills-es5) 713 kB [initial] [rendered]
12:14:42 AM: chunk {0} 0-es2015.js, 0-es2015.js.map () 31.1 kB [rendered]
12:14:42 AM: chunk {0} 0-es5.js, 0-es5.js.map () 36.8 kB [rendered]
12:14:42 AM: chunk {1} 1-es2015.js, 1-es2015.js.map () 31.1 kB [rendered]
12:14:42 AM: chunk {1} 1-es5.js, 1-es5.js.map () 36.8 kB [rendered]
12:14:42 AM: chunk {2} 2-es2015.js, 2-es2015.js.map () 47.7 kB [rendered]
12:14:42 AM: chunk {2} 2-es5.js, 2-es5.js.map () 55.3 kB [rendered]
12:14:42 AM: chunk {3} 3-es2015.js, 3-es2015.js.map () 47.7 kB [rendered]
12:14:43 AM: Creating deploy upload records
12:14:42 AM: chunk {3} 3-es5.js, 3-es5.js.map () 55.3 kB [rendered]
12:14:42 AM: chunk {4} 4-es2015.js, 4-es2015.js.map () 67.8 kB [rendered]
12:14:42 AM: chunk {4} 4-es5.js, 4-es5.js.map () 90.9 kB [rendered]
12:14:42 AM: chunk {5} 5-es2015.js, 5-es2015.js.map () 67.8 kB [rendered]
12:14:42 AM: chunk {5} 5-es5.js, 5-es5.js.map () 90.9 kB [rendered]
12:14:42 AM: chunk {6} 6-es2015.js, 6-es2015.js.map () 6.33 kB [rendered]
12:14:42 AM: chunk {6} 6-es5.js, 6-es5.js.map () 8.13 kB [rendered]
12:14:42 AM: chunk {7} 7-es2015.js, 7-es2015.js.map () 6.33 kB [rendered]
12:14:42 AM: chunk {7} 7-es5.js, 7-es5.js.map () 8.13 kB [rendered]
12:14:42 AM: chunk {8} 8-es2015.js, 8-es2015.js.map () 16.5 kB [rendered]
12:14:42 AM: chunk {8} 8-es5.js, 8-es5.js.map () 20.7 kB [rendered]
12:14:42 AM: chunk {9} 9-es2015.js, 9-es2015.js.map () 16.5 kB [rendered]
12:14:42 AM: chunk {9} 9-es5.js, 9-es5.js.map () 20.7 kB [rendered]
12:14:42 AM: chunk {10} 10-es2015.js, 10-es2015.js.map () 3.77 kB [rendered]
12:14:42 AM: chunk {10} 10-es5.js, 10-es5.js.map () 5.38 kB [rendered]
12:14:42 AM: chunk {11} 11-es2015.js, 11-es2015.js.map () 3.76 kB [rendered]
12:14:42 AM: chunk {11} 11-es5.js, 11-es5.js.map () 5.38 kB [rendered]
12:14:42 AM: chunk {12} 12-es2015.js, 12-es2015.js.map () 33.9 kB [rendered]
12:14:42 AM: chunk {12} 12-es5.js, 12-es5.js.map () 37.7 kB [rendered]
12:14:42 AM: chunk {13} 13-es2015.js, 13-es2015.js.map () 33.9 kB [rendered]
12:14:42 AM: chunk {13} 13-es5.js, 13-es5.js.map () 37.7 kB [rendered]
12:14:42 AM: chunk {14} 14-es2015.js, 14-es2015.js.map () 17.1 kB [rendered]
12:14:42 AM: chunk {14} 14-es5.js, 14-es5.js.map () 20.1 kB [rendered]
12:14:42 AM: chunk {15} 15-es2015.js, 15-es2015.js.map () 17.1 kB [rendered]
12:14:44 AM: Starting post processing
12:14:42 AM: chunk {15} 15-es5.js, 15-es5.js.map () 20.1 kB [rendered]
12:14:42 AM: chunk {16} 16-es2015.js, 16-es2015.js.map () 11.6 kB [rendered]
12:14:42 AM: chunk {16} 16-es5.js, 16-es5.js.map () 14.2 kB [rendered]
12:14:42 AM: chunk {17} 17-es2015.js, 17-es2015.js.map () 11.6 kB [rendered]
12:14:42 AM: chunk {17} 17-es5.js, 17-es5.js.map () 14.2 kB [rendered]
12:14:42 AM: chunk {18} 18-es2015.js, 18-es2015.js.map () 9.8 kB [rendered]
12:14:42 AM: chunk {18} 18-es5.js, 18-es5.js.map () 11.2 kB [rendered]
12:14:42 AM: chunk {19} 19-es2015.js, 19-es2015.js.map () 9.8 kB [rendered]
12:14:44 AM: Post processing - HTML
12:14:42 AM: chunk {19} 19-es5.js, 19-es5.js.map () 11.2 kB [rendered]
12:14:42 AM: chunk {20} 20-es2015.js, 20-es2015.js.map () 16.3 kB [rendered]
12:14:42 AM: chunk {20} 20-es5.js, 20-es5.js.map () 20.3 kB [rendered]
12:14:42 AM: chunk {21} 21-es2015.js, 21-es2015.js.map () 78.5 kB [rendered]
12:14:42 AM: chunk {21} 21-es5.js, 21-es5.js.map () 94.9 kB [rendered]
12:14:44 AM: Post processing - header rules
12:14:42 AM: chunk {22} 22-es2015.js, 22-es2015.js.map () 78.5 kB [rendered]
12:14:42 AM: chunk {22} 22-es5.js, 22-es5.js.map () 94.9 kB [rendered]
12:14:42 AM: chunk {23} 23-es2015.js, 23-es2015.js.map () 27.5 kB [rendered]
12:14:42 AM: chunk {23} 23-es5.js, 23-es5.js.map () 32.3 kB [rendered]
12:14:44 AM: Post processing - redirect rules
12:14:42 AM: chunk {24} 24-es2015.js, 24-es2015.js.map () 27.5 kB [rendered]
12:14:42 AM: chunk {24} 24-es5.js, 24-es5.js.map () 32.3 kB [rendered]
12:14:42 AM: chunk {25} 25-es2015.js, 25-es2015.js.map () 3.7 kB [rendered]
12:14:44 AM: Post processing done
12:14:42 AM: chunk {25} 25-es5.js, 25-es5.js.map () 5.31 kB [rendered]
12:14:42 AM: chunk {26} 26-es2015.js, 26-es2015.js.map () 14.3 kB [rendered]
12:14:42 AM: chunk {26} 26-es5.js, 26-es5.js.map () 19.4 kB [rendered]
12:14:42 AM: chunk {27} 27-es2015.js, 27-es2015.js.map () 14.3 kB [rendered]
12:14:42 AM: chunk {27} 27-es5.js, 27-es5.js.map () 19.4 kB [rendered]
12:14:42 AM: chunk {28} 28-es2015.js, 28-es2015.js.map () 19.8 kB [rendered]
12:14:42 AM: chunk {28} 28-es5.js, 28-es5.js.map () 24.2 kB [rendered]
12:14:42 AM: chunk {29} 29-es2015.js, 29-es2015.js.map () 19.8 kB [rendered]
12:14:42 AM: chunk {29} 29-es5.js, 29-es5.js.map () 24.1 kB [rendered]
12:14:42 AM: chunk {30} 30-es2015.js, 30-es2015.js.map () 33.6 kB [rendered]
12:14:42 AM: chunk {30} 30-es5.js, 30-es5.js.map () 44.8 kB [rendered]
12:14:42 AM: chunk {31} 31-es2015.js, 31-es2015.js.map () 33.5 kB [rendered]
12:14:42 AM: chunk {31} 31-es5.js, 31-es5.js.map () 44.8 kB [rendered]
12:14:42 AM: chunk {33} 33-es2015.js, 33-es2015.js.map () 70.4 kB [rendered]
12:14:42 AM: chunk {33} 33-es5.js, 33-es5.js.map () 77.9 kB [rendered]
12:14:42 AM: chunk {34} 34-es2015.js, 34-es2015.js.map () 16 kB [rendered]
12:14:42 AM: chunk {34} 34-es5.js, 34-es5.js.map () 19.7 kB [rendered]
12:14:42 AM: chunk {35} 35-es2015.js, 35-es2015.js.map () 16 kB [rendered]
12:14:42 AM: chunk {35} 35-es5.js, 35-es5.js.map () 19.7 kB [rendered]
12:14:42 AM: chunk {36} 36-es2015.js, 36-es2015.js.map () 35 kB [rendered]
12:14:42 AM: chunk {36} 36-es5.js, 36-es5.js.map () 49.5 kB [rendered]
12:14:42 AM: chunk {37} 37-es2015.js, 37-es2015.js.map () 35 kB [rendered]
12:14:42 AM: chunk {37} 37-es5.js, 37-es5.js.map () 49.5 kB [rendered]
12:14:42 AM: chunk {38} 38-es2015.js, 38-es2015.js.map () 29.3 kB [rendered]
12:14:42 AM: chunk {38} 38-es5.js, 38-es5.js.map () 35.4 kB [rendered]
12:14:42 AM: chunk {39} 39-es2015.js, 39-es2015.js.map () 29.3 kB [rendered]
12:14:42 AM: chunk {39} 39-es5.js, 39-es5.js.map () 35.4 kB [rendered]
12:14:42 AM: chunk {32} 32-es2015.js, 32-es2015.js.map () 70.4 kB [rendered]
12:14:42 AM: chunk {32} 32-es5.js, 32-es5.js.map () 77.9 kB [rendered]
12:14:42 AM: chunk {40} 40-es2015.js, 40-es2015.js.map () 35.1 kB [rendered]
12:14:42 AM: chunk {40} 40-es5.js, 40-es5.js.map () 50.8 kB [rendered]
12:14:42 AM: chunk {41} 41-es2015.js, 41-es2015.js.map () 22.5 kB [rendered]
12:14:42 AM: chunk {41} 41-es5.js, 41-es5.js.map () 27.2 kB [rendered]
12:14:42 AM: chunk {43} 43-es2015.js, 43-es2015.js.map () 21.7 kB m [rendered]
12:14:42 AM: chunk {43} 43-es5.js, 43-es5.js.map () 23.5 kB [rendered]
12:14:42 AM: chunk {44} 44-es2015.js, 44-es2015.js.map () 21.7 kB [rendered]
12:14:42 AM: chunk {44} 44-es5.js, 44-es5.js.map () 23.5 kB [rendered]
12:14:42 AM: chunk {45} 45-es2015.js, 45-es2015.js.map () 13 kB [rendered]
12:14:42 AM: chunk {45} 45-es5.js, 45-es5.js.map () 17.2 kB [rendered]
12:14:42 AM: chunk {42} 42-es2015.js, 42-es2015.js.map () 22.5 kB [rendered]
12:14:42 AM: chunk {42} 42-es5.js, 42-es5.js.map () 27.2 kB [rendered]
12:14:42 AM: chunk {46} 46-es2015.js, 46-es2015.js.map () 12.9 kB [rendered]
12:14:42 AM: chunk {46} 46-es5.js, 46-es5.js.map () 17.2 kB [rendered]
12:14:42 AM: chunk {50} 50-es2015.js, 50-es2015.js.map () 50.4 kB [rendered]
12:14:42 AM: chunk {50} 50-es5.js, 50-es5.js.map () 66.3 kB [rendered]
12:14:42 AM: chunk {53} 53-es2015.js, 53-es2015.js.map () 6.58 kB [rendered]
12:14:42 AM: chunk {53} 53-es5.js, 53-es5.js.map () 9.7 kB [rendered]
12:14:42 AM: chunk {51} 51-es2015.js, 51-es2015.js.map () 13.2 kB [rendered]
12:14:42 AM: chunk {51} 51-es5.js, 51-es5.js.map () 18.2 kB [rendered]
12:14:42 AM: chunk {52} 52-es2015.js, 52-es2015.js.map () 13.2 kB [rendered]
12:14:42 AM: chunk {52} 52-es5.js, 52-es5.js.map () 18.2 kB [rendered]
12:14:42 AM: chunk {54} 54-es2015.js, 54-es2015.js.map () 24.5 kB [rendered]
12:14:42 AM: chunk {54} 54-es5.js, 54-es5.js.map () 46.3 kB [rendered]
12:14:42 AM: chunk {55} 55-es2015.js, 55-es2015.js.map () 33.4 kB [rendered]
12:14:42 AM: chunk {55} 55-es5.js, 55-es5.js.map () 38.1 kB [rendered]
12:14:42 AM: chunk {56} 56-es2015.js, 56-es2015.js.map () 33.4 kB [rendered]
12:14:42 AM: chunk {56} 56-es5.js, 56-es5.js.map () 38.1 kB [rendered]
12:14:42 AM: chunk {57} 57-es2015.js, 57-es2015.js.map () 37.9 kB [rendered]
12:14:42 AM: chunk {57} 57-es5.js, 57-es5.js.map () 46.4 kB [rendered]
12:14:42 AM: chunk {58} 58-es2015.js, 58-es2015.js.map () 37.9 kB [rendered]
12:14:42 AM: chunk {58} 58-es5.js, 58-es5.js.map () 46.4 kB [rendered]
12:14:42 AM: chunk {59} 59-es2015.js, 59-es2015.js.map () 25.7 kB [rendered]
12:14:42 AM: chunk {59} 59-es5.js, 59-es5.js.map () 36.3 kB [rendered]
12:14:42 AM: chunk {60} 60-es2015.js, 60-es2015.js.map () 25.7 kB [rendered]
12:14:42 AM: chunk {60} 60-es5.js, 60-es5.js.map () 36.3 kB [rendered]
12:14:42 AM: chunk {61} 61-es2015.js, 61-es2015.js.map () 58.2 kB [rendered]
12:14:42 AM: chunk {61} 61-es5.js, 61-es5.js.map () 78 kB [rendered]
12:14:42 AM: chunk {62} 62-es2015.js, 62-es2015.js.map () 58.2 kB [rendered]
12:14:42 AM: chunk {62} 62-es5.js, 62-es5.js.map () 78 kB [rendered]
12:14:42 AM: chunk {63} 63-es2015.js, 63-es2015.js.map () 8.26 kB [rendered]
12:14:42 AM: chunk {63} 63-es5.js, 63-es5.js.map () 9.99 kB [rendered]
12:14:42 AM: chunk {64} 64-es2015.js, 64-es2015.js.map () 10 kB [rendered]
12:14:42 AM: chunk {64} 64-es5.js, 64-es5.js.map () 12 kB [rendered]
12:14:42 AM: chunk {66} 66-es2015.js, 66-es2015.js.map () 24.2 kB [rendered]
12:14:42 AM: chunk {66} 66-es5.js, 66-es5.js.map () 27.5 kB [rendered]
12:14:47 AM: Site is live ✨
12:14:42 AM: chunk {65} 65-es2015.js, 65-es2015.js.map () 10 kB [rendered]
12:14:42 AM: chunk {65} 65-es5.js, 65-es5.js.map () 12 kB [rendered]
12:14:42 AM: chunk {68} 68-es2015.js, 68-es2015.js.map () 8.73 kB [rendered]
12:14:42 AM: chunk {68} 68-es5.js, 68-es5.js.map () 17.9 kB [rendered]
12:14:42 AM: chunk {67} 67-es2015.js, 67-es2015.js.map () 24.2 kB [rendered]
12:14:42 AM: chunk {67} 67-es5.js, 67-es5.js.map () 27.5 kB [rendered]
12:14:42 AM: chunk {69} 69-es2015.js, 69-es2015.js.map () 1.96 kB [rendered]
12:14:42 AM: chunk {69} 69-es5.js, 69-es5.js.map () 3.22 kB [rendered]
12:14:42 AM: chunk {71} 71-es2015.js, 71-es2015.js.map () 17.6 kB [rendered]
12:14:42 AM: chunk {71} 71-es5.js, 71-es5.js.map () 21.9 kB [rendered]
12:14:42 AM: chunk {70} 70-es2015.js, 70-es2015.js.map () 17.6 kB [rendered]
12:14:42 AM: chunk {70} 70-es5.js, 70-es5.js.map () 21.9 kB [rendered]
12:14:42 AM: chunk {73} 73-es2015.js, 73-es2015.js.map () 23.2 kB [rendered]
12:14:42 AM: chunk {73} 73-es5.js, 73-es5.js.map () 29.7 kB [rendered]
12:14:42 AM: chunk {75} 75-es2015.js, 75-es2015.js.map () 17.4 kB [rendered]
12:14:42 AM: chunk {75} 75-es5.js, 75-es5.js.map () 22 kB [rendered]
12:14:42 AM: chunk {74} 74-es2015.js, 74-es2015.js.map () 17.4 kB [rendered]
12:14:42 AM: chunk {74} 74-es5.js, 74-es5.js.map () 22 kB [rendered]
12:14:42 AM: chunk {76} 76-es2015.js, 76-es2015.js.map () 19.9 kB [rendered]
12:14:42 AM: chunk {76} 76-es5.js, 76-es5.js.map () 28.6 kB [rendered]
12:14:42 AM: chunk {common} common-es2015.js, common-es2015.js.map (common) 14.7 kB [rendered]
12:14:42 AM: chunk {common} common-es5.js, common-es5.js.map (common) 19.3 kB [rendered]
12:14:42 AM: chunk {components-misc-scanopnieuw-scanopnieuw-module} components-misc-scanopnieuw-scanopnieuw-module-es2015.js, components-misc-scanopnieuw-scanopnieuw-module-es2015.js.map (components-misc-scanopnieuw-scanopnieuw-module) 10.6 kB [rendered]
12:14:42 AM: chunk {components-misc-scanopnieuw-scanopnieuw-module} components-misc-scanopnieuw-scanopnieuw-module-es5.js, components-misc-scanopnieuw-scanopnieuw-module-es5.js.map (components-misc-scanopnieuw-scanopnieuw-module) 12.3 kB [rendered]
12:14:42 AM: chunk {core-cadeaubon-cadeaubon-module} core-cadeaubon-cadeaubon-module-es2015.js, core-cadeaubon-cadeaubon-module-es2015.js.map (core-cadeaubon-cadeaubon-module) 2.65 kB [rendered]
12:14:42 AM: chunk {core-cadeaubon-cadeaubon-module} core-cadeaubon-cadeaubon-module-es5.js, core-cadeaubon-cadeaubon-module-es5.js.map (core-cadeaubon-cadeaubon-module) 3.03 kB [rendered]
12:14:42 AM: chunk {core-loading-page-loading-page-module} core-loading-page-loading-page-module-es2015.js, core-loading-page-loading-page-module-es2015.js.map (core-loading-page-loading-page-module) 2.69 kB [rendered]
12:14:42 AM: chunk {core-loading-page-loading-page-module} core-loading-page-loading-page-module-es5.js, core-loading-page-loading-page-module-es5.js.map (core-loading-page-loading-page-module) 3.08 kB [rendered]
12:14:42 AM: chunk {core-recensies-recensies-module} core-recensies-recensies-module-es2015.js, core-recensies-recensies-module-es2015.js.map (core-recensies-recensies-module) 2.89 kB [rendered]
12:14:42 AM: chunk {core-recensies-recensies-module} core-recensies-recensies-module-es5.js, core-recensies-recensies-module-es5.js.map (core-recensies-recensies-module) 3.27 kB [rendered]
12:14:42 AM: chunk {deprecated-bonsai-bestel-fail-bonsai-bestel-fail-module} deprecated-bonsai-bestel-fail-bonsai-bestel-fail-module-es2015.js, deprecated-bonsai-bestel-fail-bonsai-bestel-fail-module-es2015.js.map (deprecated-bonsai-bestel-fail-bonsai-bestel-fail-module) 2.89 kB [rendered]
12:14:42 AM: chunk {deprecated-bonsai-bestel-fail-bonsai-bestel-fail-module} deprecated-bonsai-bestel-fail-bonsai-bestel-fail-module-es5.js, deprecated-bonsai-bestel-fail-bonsai-bestel-fail-module-es5.js.map (deprecated-bonsai-bestel-fail-bonsai-bestel-fail-module) 3.3 kB [rendered]
12:14:42 AM: chunk {deprecated-bonsai-bestel-oke-bonsai-bestel-oke-module} deprecated-bonsai-bestel-oke-bonsai-bestel-oke-module-es2015.js, deprecated-bonsai-bestel-oke-bonsai-bestel-oke-module-es2015.js.map (deprecated-bonsai-bestel-oke-bonsai-bestel-oke-module) 2.87 kB [rendered]
12:14:42 AM: chunk {deprecated-bonsai-bestel-oke-bonsai-bestel-oke-module} deprecated-bonsai-bestel-oke-bonsai-bestel-oke-module-es5.js, deprecated-bonsai-bestel-oke-bonsai-bestel-oke-module-es5.js.map (deprecated-bonsai-bestel-oke-bonsai-bestel-oke-module) 3.27 kB [rendered]
12:14:42 AM: chunk {input-shims-d4609e0d-js} input-shims-d4609e0d-js-es2015.js, input-shims-d4609e0d-js-es2015.js.map (input-shims-d4609e0d-js) 15.3 kB [rendered]
12:14:42 AM: chunk {input-shims-d4609e0d-js} input-shims-d4609e0d-js-es5.js, input-shims-d4609e0d-js-es5.js.map (input-shims-d4609e0d-js) 20.4 kB [rendered]
12:14:42 AM: chunk {focus-visible-15ada7f7-js} focus-visible-15ada7f7-js-es2015.js, focus-visible-15ada7f7-js-es2015.js.map (focus-visible-15ada7f7-js) 2.12 kB [rendered]
12:14:42 AM: chunk {focus-visible-15ada7f7-js} focus-visible-15ada7f7-js-es5.js, focus-visible-15ada7f7-js-es5.js.map (focus-visible-15ada7f7-js) 2.38 kB [rendered]
12:14:42 AM: chunk {72} 72-es2015.js, 72-es2015.js.map () 23.2 kB [rendered]
12:14:42 AM: chunk {72} 72-es5.js, 72-es5.js.map () 29.7 kB [rendered]
12:14:42 AM: chunk {main} main-es2015.js, main-es2015.js.map (main) 1.65 MB [initial] [rendered]
12:14:42 AM: chunk {main} main-es5.js, main-es5.js.map (main) 1.69 MB [initial] [rendered]
12:14:42 AM: chunk {oke-components-register-oke-register-oke-module} oke-components-register-oke-register-oke-module-es2015.js, oke-components-register-oke-register-oke-module-es2015.js.map (oke-components-register-oke-register-oke-module) 11.1 kB [rendered]
12:14:42 AM: chunk {oke-components-register-oke-register-oke-module} oke-components-register-oke-register-oke-module-es5.js, oke-components-register-oke-register-oke-module-es5.js.map (oke-components-register-oke-register-oke-module) 12.8 kB [rendered]
12:14:42 AM: chunk {polyfills-core-js} polyfills-core-js-es2015.js, polyfills-core-js-es2015.js.map (polyfills-core-js) 78.7 kB [rendered]
12:14:42 AM: chunk {polyfills-core-js} polyfills-core-js-es5.js, polyfills-core-js-es5.js.map (polyfills-core-js) 151 kB [rendered]
12:14:42 AM: chunk {polyfills-css-shim} polyfills-css-shim-es2015.js, polyfills-css-shim-es2015.js.map (polyfills-css-shim) 10.5 kB [rendered]
12:14:42 AM: chunk {polyfills-css-shim} polyfills-css-shim-es5.js, polyfills-css-shim-es5.js.map (polyfills-css-shim) 14.6 kB [rendered]
12:14:42 AM: chunk {polyfills-dom} polyfills-dom-es2015.js, polyfills-dom-es2015.js.map (polyfills-dom) 38.5 kB [rendered]
12:14:42 AM: chunk {polyfills-dom} polyfills-dom-es5.js, polyfills-dom-es5.js.map (polyfills-dom) 62.1 kB [rendered]
12:14:42 AM: chunk {keyboard-a2b5e51d-js} keyboard-a2b5e51d-js-es2015.js, keyboard-a2b5e51d-js-es2015.js.map (keyboard-a2b5e51d-js) 7.28 kB [rendered]
12:14:42 AM: chunk {keyboard-a2b5e51d-js} keyboard-a2b5e51d-js-es5.js, keyboard-a2b5e51d-js-es5.js.map (keyboard-a2b5e51d-js) 8.41 kB [rendered]
12:14:42 AM: chunk {popups-bevestigbestelling-bevestigingbestelling-module} popups-bevestigbestelling-bevestigingbestelling-module-es2015.js, popups-bevestigbestelling-bevestigingbestelling-module-es2015.js.map (popups-bevestigbestelling-bevestigingbestelling-module) 4.19 kB [rendered]
12:14:42 AM: chunk {popups-bevestigbestelling-bevestigingbestelling-module} popups-bevestigbestelling-bevestigingbestelling-module-es5.js, popups-bevestigbestelling-bevestigingbestelling-module-es5.js.map (popups-bevestigbestelling-bevestigingbestelling-module) 4.6 kB [rendered]
12:14:42 AM: chunk {shadow-css-7f9c6860-js} shadow-css-7f9c6860-js-es2015.js, shadow-css-7f9c6860-js-es2015.js.map (shadow-css-7f9c6860-js) 15.9 kB [rendered]
12:14:42 AM: chunk {shadow-css-7f9c6860-js} shadow-css-7f9c6860-js-es5.js, shadow-css-7f9c6860-js-es5.js.map (shadow-css-7f9c6860-js) 18.8 kB [rendered]
12:14:42 AM: chunk {runtime} runtime-es2015.js, runtime-es2015.js.map (runtime) 10.2 kB [entry] [rendered]
12:14:42 AM: chunk {runtime} runtime-es5.js, runtime-es5.js.map (runtime) 10.2 kB [entry] [rendered]
12:14:42 AM: chunk {status-tap-171795fe-js} status-tap-171795fe-js-es2015.js, status-tap-171795fe-js-es2015.js.map (status-tap-171795fe-js) 1.61 kB [rendered]
12:14:42 AM: chunk {status-tap-171795fe-js} status-tap-171795fe-js-es5.js, status-tap-171795fe-js-es5.js.map (status-tap-171795fe-js) 1.77 kB [rendered]
12:14:42 AM: chunk {styles} styles-es2015.js, styles-es2015.js.map (styles) 1.85 MB [initial] [rendered]
12:14:42 AM: chunk {styles} styles-es5.js, styles-es5.js.map (styles) 1.85 MB [initial] [rendered]
12:14:42 AM: chunk {swiper-bundle-e8f38f34-js} swiper-bundle-e8f38f34-js-es2015.js, swiper-bundle-e8f38f34-js-es2015.js.map (swiper-bundle-e8f38f34-js) 196 kB [rendered]
12:14:42 AM: chunk {swiper-bundle-e8f38f34-js} swiper-bundle-e8f38f34-js-es5.js, swiper-bundle-e8f38f34-js-es5.js.map (swiper-bundle-e8f38f34-js) 234 kB [rendered]
12:14:42 AM: chunk {swipe-back-0a6a44c8-js} swipe-back-0a6a44c8-js-es2015.js, swipe-back-0a6a44c8-js-es2015.js.map (swipe-back-0a6a44c8-js) 3.06 kB [rendered]
12:14:42 AM: chunk {swipe-back-0a6a44c8-js} swipe-back-0a6a44c8-js-es5.js, swipe-back-0a6a44c8-js-es5.js.map (swipe-back-0a6a44c8-js) 3.29 kB [rendered]
12:14:42 AM: chunk {tap-click-252af35a-js} tap-click-252af35a-js-es2015.js, tap-click-252af35a-js-es2015.js.map (tap-click-252af35a-js) 6.23 kB [rendered]
12:14:42 AM: chunk {tap-click-252af35a-js} tap-click-252af35a-js-es5.js, tap-click-252af35a-js-es5.js.map (tap-click-252af35a-js) 6.73 kB [rendered]
12:14:42 AM: chunk {49} 49-es2015.js, 49-es2015.js.map () 50.4 kB [rendered]
12:14:42 AM: chunk {49} 49-es5.js, 49-es5.js.map () 66.3 kB [rendered]
12:14:42 AM: chunk {47} 47-es2015.js, 47-es2015.js.map9m () 28.4 kB [rendered]
12:14:42 AM: chunk {47} 47-es5.js, 47-es5.js.map () 34.5 kB [rendered]
12:14:42 AM: chunk {48} 48-es2015.js, 48-es2015.js.map () 28.4 kB [rendered]
12:14:42 AM: chunk {48} 48-es5.js, 48-es5.js.map () 34.5 kB [rendered]
12:14:42 AM: chunk {vendor} vendor-es2015.js, vendor-es2015.js.map (vendor) 9.19 MB [initial] [rendered]
12:14:42 AM: chunk {vendor} vendor-es5.js, vendor-es5.js.map (vendor) 10.5 MB [initial] [rendered]
12:14:42 AM: Date: 2022-04-06T22:14:42.712Z - Hash: fedc7443bd851e919173 - Time: 31099ms
12:14:42 AM: WARNING in /opt/build/repo/src/test.ts is part of the TypeScript compilation but it's unused.
Add only entry points to the 'files' or 'include' properties in your tsconfig.
12:14:42 AM: WARNING in /opt/build/repo/src/app/components/oke-components/add-extra-oke/add-extra-oke.module.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/app/components/popups/alcohol-popup/alcohol-popup.module.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/app/components/popups/bevestigrecensie/bevestigrecensie.module.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/app/components/popups/blok-bestellen/blok-bestellen.module.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/app/models/amount.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/app/models/payment.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/app/services/resolvers/auth.resolver.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/app/services/resolvers/resolve.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/environments/environment.local.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM: WARNING in /opt/build/repo/src/environments/environment.prod.ts is part of the TypeScript compilation but it's unused.
12:14:42 AM:
12:14:42 AM: (build.command completed in 34.5s)
12:14:42 AM:
12:14:42 AM: ────────────────────────────────────────────────────────────────
12:14:42 AM: 2. Deploy site
12:14:42 AM:
12:14:42 AM: Starting to deploy site from 'www'
12:14:42 AM: Creating deploy tree asynchronously
12:14:49 AM: 0 new files to upload
12:14:49 AM: 0 new functions to upload
12:14:49 AM: Site deploy was successfully initiated
12:14:49 AM:
12:14:49 AM: (Deploy site completed in 6.4s)
12:14:49 AM:
12:14:49 AM: ────────────────────────────────────────────────────────────────
12:14:49 AM: Netlify Build Complete
12:14:49 AM:
12:14:49 AM: (Netlify Build completed in 41s)
12:14:49 AM: Caching artifacts
12:14:49 AM: Started saving node modules
12:14:49 AM: Finished saving node modules
12:14:49 AM: Started saving build plugins
12:14:49 AM: Finished saving build plugins
12:14:49 AM: Started saving pip cache
12:14:49 AM: Finished saving pip cache
12:14:49 AM: Started saving emacs cask dependencies
12:14:49 AM: Finished saving emacs cask dependencies
12:14:49 AM: Started saving maven dependencies
12:14:49 AM: Finished saving maven dependencies
12:14:49 AM: Started saving boot dependencies
12:14:49 AM: Finished saving boot dependencies
12:14:49 AM: Started saving rust rustup cache
12:14:49 AM: Finished saving rust rustup cache
12:14:49 AM: Started saving go dependencies
12:14:49 AM: Finished saving go dependencies
12:14:49 AM: Build script success
12:15:49 AM: Finished processing build request in 2m15.385104336s
