Disabling URL for a site without deleting the Netlify project
Hello,
I know how to stop auto-publish builds.
I know how to unlink from the repo.
I’d like to keep the project xyz around in case I need it later on, and at the same time, I don’t want it to be published on a URL xyz.netlify.app. Is that possible? In other words, keep the project but not publish anything.
Thanks for your help!
hi there,
is this helpful at all?
Thanks. The manual deploy created a new website, when I just wanted to replace the current one.
No worries, I just killed the entire project. If needed, I’ll create a new one and will connect to the repo.
Thanks,
Thanks for letting us know. We’ll be here if you encounter future questions. Happy building!
