I have a nuxtjs website with netlify functions.
It has been deployed successfully hundreds of time with this netlify.toml
file:
[build]
publish = "dist"
command = "netlify-lambda build api && nuxt build"
functions = "./functions"
Now suddenly the deploy fails with this log:
type or past9:20:48 PM: $ netlify-lambda build api && nuxt build
9:20:49 PM: netlify-lambda: Building functions
9:20:51 PM: ModuleNotFoundError: Module not found: Error: Can't resolve 'npm install' in '/opt/build/repo/api'
at factory.create (/opt/build/repo/node_modules/webpack/lib/Compilation.js:925:10)
9:20:51 PM: at factory (/opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js:401:22)
9:20:51 PM: at resolver (/opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js:130:21)
9:20:51 PM: at asyncLib.parallel (/opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js:224:22)
9:20:51 PM: at /opt/build/repo/node_modules/neo-async/async.js:2830:7
9:20:51 PM: at /opt/build/repo/node_modules/neo-async/async.js:6877:13
9:20:51 PM: at normalResolver.resolve (/opt/build/repo/node_modules/webpack/lib/NormalModuleFactory.js:214:25)
9:20:51 PM: at doResolve (/opt/build/repo/node_modules/enhanced-resolve/lib/Resolver.js:213:14)
9:20:51 PM: at hook.callAsync (/opt/build/repo/node_modules/enhanced-resolve/lib/Resolver.js:285:5)
9:20:51 PM: at _fn0 (eval at create (/opt/build/repo/node_modules/tapable/lib/HookCodeFactory.js:33:10), <anonymous>:15:1)
9:20:51 PM: at resolver.doResolve (/opt/build/repo/node_modules/enhanced-resolve/lib/UnsafeCachePlugin.js:44:7)
9:20:51 PM: at _fn0 (eval at create (/opt/build/repo/node_modules/tapable/lib/HookCodeFactory.js:33:10), <anonymous>:27:1)
9:20:51 PM: at resolver.doResolve (/opt/build/repo/node_modules/enhanced-resolve/lib/DescriptionFilePlugin.js:67:43)
9:20:51 PM: resolve 'npm install' in '/opt/build/repo/api'
9:20:51 PM: Parsed request is a module
9:20:51 PM: using description file: /opt/build/repo/package.json (relative path: ./api)
9:20:51 PM: resolve as module
9:20:51 PM: /opt/build/repo/api/node_modules doesn't exist or is not a directory
/opt/build/node_modules doesn't exist or is not a directory
/opt/node_modules doesn't exist or is not a directory
looking for modules in /opt/build/repo/node_modules
9:20:51 PM: using description file: /opt/build/repo/package.json (relative path: ./node_modules)
9:20:51 PM: using description file: /opt/build/repo/package.json (relative path: ./node_modules/npm install)
9:20:51 PM: no extension
9:20:51 PM: /opt/build/repo/node_modules/npm install doesn't exist
.wasm
9:20:51 PM: /opt/build/repo/node_modules/npm install.wasm doesn't exist
.mjs
9:20:51 PM: /opt/build/repo/node_modules/npm install.mjs doesn't exist
.js
9:20:51 PM: /opt/build/repo/node_modules/npm install.js doesn't exist
.json
9:20:51 PM: /opt/build/repo/node_modules/npm install.json doesn't exist
.ts
9:20:51 PM: /opt/build/repo/node_modules/npm install.ts doesn't exist
as directory
9:20:51 PM: ────────────────────────────────────────────────────────────────
9:20:51 PM: "build.command" failed
9:20:51 PM:
9:20:51 PM: Error message
9:20:51 PM: Command failed with exit code 1: netlify-lambda build api && nuxt build
9:20:51 PM:
9:20:51 PM: Error location
9:20:51 PM: In build.command from netlify.toml:
9:20:51 PM: netlify-lambda build api && nuxt build
9:20:51 PM:
9:20:51 PM: Resolved config
What can be the reason?
