Creating a subdomain for a site not hosted on Netlify
Hello!
Here’s the info:
Netlify site name: crossfitmazamet.netlify.app
custom domain: crossfitmazamet.fr
Domain registrar: OVH
This site is hosted on Netlify, and I have setup Netlify DNS without trouble.
Now, another developer has created a shop for my site, which I’d like to point to a subdomain, like shop.crossfitmazamet.fr. That shop is most likely not hosted on Netlify.
This is the first time I’ve done that, and all the documentation on Netlify actually got me more confused than anything else.
if possible, I’d like to have Netlify DNS handle that, and reading some docs, it seems that it’s possible. I’ve read Delegate a standalone subdomain, but it looks like that’s only for sites hosted on Netlify.
Do I need to go to `teams/[myteam]/dns/crossfitmazamet.fr and add a new record there? If so, how do I fill in these fields? Where do I write my subdomain name of choice?
Thank you for any help you may give!
Edit: After posting this, I saw a post that seems to help me figure things out. This one hadn’t come up in my netlify forum search, but only in the Suggestions below my post. Will delete my OP after the process.
Hi, @BuckyBuck135. To point a subdomain to third-party hosting, you will need to make a DNS record in Netlify DNS that points to that other hosting.
The other hosting provider will tell you what type of DNS record to make. It will normally be an A type or CNAME type DNS record. Netlify cannot tell you what record you need to make. Only the third-party host can provide those instructions.
Once you know what record you want to make, you will then create it within the DNS zone at Netlify. If that does not work or if there are any questions, please let us know.
Hi Luke,
Thank you for reaching out.
I had found a solution, but your post also explains how to solve very clearly. Thanks for that.
Once I had the CNAME information, it was very easy and intuitive to create a CNAME record with Netlify DNS.
