code is working fine locally but deployment is failing on netlify.
Hi @Anoosha0-Shetty welcome to the forums! I’m glad you found us. This was a known bug but has since been solved. Can you take a look at this issue and see if the solution proposed solved your problem?
@SamO Thank you. I will take a look at it.
