Setup my site and deployed it successfully using an external domain host (godaddy). Wanted to make revisions and instead of just letting the initial deployment alone I went and deleted it. I re-deployed the site under the same domain, waited 24hrs. and I’m still seeing under my Domain Management the warning for “Awaiting External DNS”.
My question is, if you delete a deployed site but keep the same domain and then deploy another site under that same domain do the initial nameservers for the original deployment need to be updated?
site: kevinhermancreative.netlify.app
url: kevinhermancreative.com
dns host: godaddly
dns servernames (initially used):
Hi there, in that domain management section, right where you have the drop-down clicked, you need to select the “Set up Netlify DNS option”. Then, please verify you still have the correct NS record values as those can change between sites. That should work!
Domains are separate to sites, sites separate to domains. You can delete a domain without deleting a site and delete a site without deleting a domain.
There are two options when using a domain with Netlify, external DNS (e.g. GoDaddy) or Netlify DNS. The screenshot shows kevinhermancreative.com is not configured correctly for either of these options.
If you have previously add kevinhermancreative.com to Netlify DNS do you see the domain listed on the Domains page of the Netlify dashboard?
If you do see it, you need to change the name server to those provided. Additionally remove the custom domain from your site then assign the custom domain.
If you don’t see it you have two options
Add the domain to Netlify DNS and add then remove / assign the custom domain as above.
