URL's Redirection problem
Hello,
I am writing to you because I have a problem with my website.
Since I published it on netlify, I have a lot of coverage problems in the google index, because it redirects the url’s without trailing slash, to the same address with trailing slash.
I have been reviewing the documentation and testing for some time without getting it to work.
I want to do a 301 redirection for all urls without trailing slash to the same url with trailing slash.
I have tried this:
https://sad-clarke-e76a78.netlify.com/* https://mycustomdomain.com/:splat 301!
But nothing has changed.
I’ve tried this:
https://mycustomdomain.com/* https://mycustomdomain.com/:splat 301!
But it gives a too many redirections error.
I don’t know what else to try… Can you help me, please?
Thank you very much.
@tnieto Welcome to the Netlify community. Have you tried turning on Asset Optimization in the Build & Deploy section of the dashboard for this site?
seems it is currently turned off - that is also my best suggestion - enabling “Pretty URLs” here: Netlify App
This may not work, but you can turn it off and on without a deploy to see if the behavior seems better.
Dear @gregraven and @fool,
Thank you for your answers and I apologize for the delay in answering you.
A few months ago I tried to activate the option “Pretty URLs”, I let some time pass (3 months approximately) to try but it didn’t work. So I turned it off again. I’ve turned it back on to try again, but I don’t have much hope that it will solve my problem.
That’s why I considered as last possibility before moving the site to other static hosting, to add the redirection I mentioned in the _redirects file of the site.
Greetings.
Hey @tnieto,
This is a very broad topic, whether a host and the infrastructure will or will not omit the trailing slash!
As our docs state, a rewrite rule ain’t gonna cut it but prettifying URLs should. As for your indexing… this should change and reflect changes when enabling pretty URLs.
Ok @Scott,
I did the change. I’m waiting for google to reindex the site to check if it has taken effect.
Thank you!
please let us know if it doesn’t!
