Netlify Site Name: https://sagarin-matchup.netlify.app/
Description: I’m trying to deploy a site that uses an edge function. The edge function imports and calls a function from another directory in the repository. Locally things run fine. However, the build/bundling step fails with the following error:
7:39:10 AM: Packaging Edge Functions from edge-function directory:
7:39:10 AM: - api
7:39:11 AM: error: Uncaught (in promise) Error: Module not found "file:///app/main.ts".
7:39:11 AM: const ret = new Error(getStringFromWasm0(arg0, arg1));
I’ve specifically chosen to use edge-functions because the primary business logic was written with the Deno runtime.
The repository directory structure example:
/app - main application code
/website
/edge-function
api.js - imports main.ts from app directory
/src - source code for astro project.
netlify.toml
netlify.toml
[build]
edge_functions = "edge-function"
base = "website"
[dev]
port = 8888
targetPort = 3000
autoLaunch = false
[[edge_functions]]
path = "/api"
function = "api"
Full error log
7:38:29 AM: Waiting for other deploys from your team to complete. Check the queue: https://app.netlify.com/teams/shea-uqrfh6q/builds
7:38:50 AM: build-image version: d7b3813f01c06610bc1723ff1b22446513ee7941 (focal)
7:38:50 AM: build-image tag: v4.14.3
7:38:50 AM: buildbot version: 4f669c94b322d52f143cdcbb17e55d40094aa06d
7:38:50 AM: Fetching cached dependencies
7:38:50 AM: Starting to download cache of 264.6KB
7:38:50 AM: Finished downloading cache in 37.572245ms
7:38:50 AM: Starting to extract cache
7:38:50 AM: Finished extracting cache in 5.736912ms
7:38:50 AM: Finished fetching cache in 85.165082ms
7:38:50 AM: Starting to prepare the repo for build
7:38:50 AM: Preparing Git Reference pull/1/head
7:38:51 AM: Parsing package.json dependencies
7:38:52 AM: Different build dir detected, going to use the one specified in the Netlify configuration file: 'website' versus '' in the Netlify UI
7:38:52 AM: Different publish path detected, going to use the one specified in the Netlify configuration file: 'website' versus '' in the Netlify UI
7:38:52 AM: Section completed: initializing
7:38:52 AM: Starting build script
7:38:52 AM: Installing dependencies
7:38:52 AM: Python version set to 2.7
7:38:53 AM: Downloading and installing node v16.18.1...
7:38:53 AM: Downloading https://nodejs.org/dist/v16.18.1/node-v16.18.1-linux-x64.tar.xz...
7:38:53 AM: Computing checksum with sha256sum
7:38:53 AM: Checksums matched!
7:38:55 AM: Now using node v16.18.1 (npm v8.19.2)
7:38:55 AM: Enabling node corepack
7:38:56 AM: Started restoring cached build plugins
7:38:56 AM: Finished restoring cached build plugins
7:38:56 AM: Attempting ruby version 2.7.2, read from environment
7:38:57 AM: Using ruby version 2.7.2
7:38:57 AM: Using PHP version 8.0
7:38:57 AM: No npm workspaces detected
7:38:57 AM: Started restoring cached node modules
7:38:57 AM: Finished restoring cached node modules
7:38:57 AM: Installing NPM modules using NPM version 8.19.2
7:39:03 AM: added 453 packages, and audited 454 packages in 5s
7:39:03 AM: 189 packages are looking for funding
7:39:03 AM: run `npm fund` for details
7:39:03 AM: found 0 vulnerabilities
7:39:03 AM: NPM modules installed
7:39:03 AM: Creating package sha
7:39:03 AM: Started restoring cached go cache
7:39:03 AM: Finished restoring cached go cache
7:39:03 AM: Installing Go version 1.17 (requested 1.17)
7:39:08 AM: unset GOOS;
7:39:08 AM: unset GOARCH;
7:39:08 AM: export GOROOT='/opt/buildhome/.gimme/versions/go1.17.linux.amd64';
7:39:08 AM: export PATH="/opt/buildhome/.gimme/versions/go1.17.linux.amd64/bin:${PATH}";
7:39:08 AM: go version >&2;
7:39:08 AM: export GIMME_ENV="/opt/buildhome/.gimme/env/go1.17.linux.amd64.env"
7:39:08 AM: go version go1.17 linux/amd64
7:39:08 AM: Detected 1 framework(s)
7:39:08 AM: "astro" at version "1.6.3"
7:39:08 AM: Installing missing commands
7:39:08 AM: Verify run directory
7:39:10 AM:
7:39:10 AM: ────────────────────────────────────────────────────────────────
7:39:10 AM: Netlify Build
7:39:10 AM:
7:39:10 AM: ❯ Version
7:39:10 AM: @netlify/build 28.1.13
7:39:10 AM:
7:39:10 AM: ❯ Flags
7:39:10 AM: baseRelDir: true
7:39:10 AM: buildId: 6378dc55f87b3400088a8ca6
7:39:10 AM: deployId: 6378dc55f87b3400088a8ca8
7:39:10 AM:
7:39:10 AM: ❯ Current directory
7:39:10 AM: /opt/build/repo/website
7:39:10 AM:
7:39:10 AM: ❯ Config file
7:39:10 AM: /opt/build/repo/website/netlify.toml
7:39:10 AM:
7:39:10 AM: ❯ Context
7:39:10 AM: deploy-preview
7:39:10 AM:
7:39:10 AM: 1. Edge Functions bundling
7:39:10 AM:
7:39:10 AM: - api
7:39:11 AM: ^
7:39:11 AM: at __wbg_new_651776e932b7e9c7 (file:///opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/vendor/deno.land/x/eszip@v0.28.0/eszip_wasm.generated.js:313:19)
7:39:11 AM: at <anonymous> (wasm://wasm/00a90a36:1:78732)
7:39:11 AM: at <anonymous> (wasm://wasm/00a90a36:1:1463894)
7:39:11 AM: at <anonymous> (wasm://wasm/00a90a36:1:1957066)
7:39:11 AM: at __wbg_adapter_18 (file:///opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/vendor/deno.land/x/eszip@v0.28.0/eszip_wasm.generated.js:144:6)
7:39:11 AM: at real (file:///opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/vendor/deno.land/x/eszip@v0.28.0/eszip_wasm.generated.js:128:14)
7:39:11 AM:
7:39:11 AM: ────────────────────────────────────────────────────────────────
7:39:11 AM: Bundling of edge function failed
7:39:11 AM:
7:39:11 AM: Error message
7:39:11 AM: Command failed with exit code 1: deno run --allow-all --no-config --quiet --import-map=/opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/vendor/import_map.json /opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/bundle.ts {"basePath":"/opt/build/repo/website","destPath":"/tmp/edge-6378dc55f87b3400088a8ca8/e7a3c673-0c36-4f1b-a890-7f60b1b63352.eszip","functions":[{"name":"api","path":"/opt/build/repo/website/edge-function/api.js"}],"importMapURL":"data:application/json;base64,eyJpbXBvcnRzIjp7Im5ldGxpZnk6ZWRnZSI6Imh0dHBzOi8vZWRnZS5uZXRsaWZ5LmNvbS92MS9pbmRleC50cyJ9fQ=="} (https://ntl.fyi/exit-code-1)
7:39:11 AM: ^
7:39:11 AM:
7:39:11 AM: Error location
7:39:11 AM: While bundling edge function
7:39:12 AM: Creating deploy upload records
7:39:11 AM:
7:39:11 AM: Resolved config
7:39:11 AM: build:
7:39:11 AM: base: /opt/build/repo/website
7:39:11 AM: edge_functions: /opt/build/repo/website/edge-function
7:39:12 AM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
7:39:11 AM: environment:
7:39:11 AM: - REVIEW_ID
7:39:11 AM: publish: /opt/build/repo/website
7:39:11 AM: publishOrigin: default
7:39:11 AM: Caching artifacts
7:39:11 AM: Started saving node modules
7:39:11 AM: Finished saving node modules
7:39:11 AM: Started saving build plugins
7:39:11 AM: Finished saving build plugins
7:39:11 AM: Started saving pip cache
7:39:11 AM: Finished saving pip cache
7:39:11 AM: Started saving emacs cask dependencies
7:39:11 AM: Finished saving emacs cask dependencies
7:39:11 AM: Started saving maven dependencies
7:39:11 AM: Finished saving maven dependencies
7:39:11 AM: Started saving boot dependencies
7:39:11 AM: Finished saving boot dependencies
7:39:11 AM: Started saving rust rustup cache
7:39:11 AM: Finished saving rust rustup cache
7:39:11 AM: Started saving go dependencies
7:39:11 AM: Finished saving go dependencies
7:39:12 AM: Build failed due to a user error: Build script returned non-zero exit code: 2
7:39:12 AM: Failing build: Failed to build site
7:39:12 AM: Finished processing build request in 22.637772304s
