As specified by the title, builds previously working is crashing due to what seems to be internal errors related to netlify building egde functions. This is currently blocking us from deploying changes.
Will include error logs.
1:38:50 PM: 6. Edge Functions bundling
1:38:50 PM: ────────────────────────────────────────────────────────────────
1:38:50 PM:
1:38:50 PM: Packaging Edge Functions from .netlify/edge-functions directory:
1:38:50 PM: - ipx
1:38:51 PM: error: Uncaught (in promise) Error: Module not found "https://edge-utils.netlify.app/1.1.0/logger/mod.ts".
1:38:51 PM: const ret = new Error(getStringFromWasm0(arg0, arg1));
1:38:51 PM: ^
1:38:51 PM: at __wbg_new_651776e932b7e9c7 (file:///opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/vendor/deno.land/x/eszip@v0.28.0/eszip_wasm.generated.js:313:19)
1:38:51 PM: at <anonymous> (wasm://wasm/00a90a36:1:78732)
1:38:51 PM: at <anonymous> (wasm://wasm/00a90a36:1:1463894)
1:38:51 PM: at <anonymous> (wasm://wasm/00a90a36:1:1957066)
1:38:51 PM: at __wbg_adapter_18 (file:///opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/vendor/deno.land/x/eszip@v0.28.0/eszip_wasm.generated.js:144:6)
1:38:51 PM: at real (file:///opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/vendor/deno.land/x/eszip@v0.28.0/eszip_wasm.generated.js:128:14)
1:38:51 PM:
1:38:51 PM: Bundling of edge function failed
1:38:52 PM: Failed during stage 'building site': Build script returned non-zero exit code: 2 (https://ntl.fyi/exit-code-2)
1:38:51 PM: ────────────────────────────────────────────────────────────────
1:38:51 PM:
1:38:51 PM: Error message
1:38:51 PM: Command failed with exit code 1: deno run --allow-all --no-config --import-map=/opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/vendor/import_map.json --quiet /opt/buildhome/node-deps/node_modules/@netlify/edge-bundler/deno/bundle.ts {"basePath":"/opt/build/repo/frontend","destPath":"/tmp/edge-63e4e8efce638f00089a255b/78e7d7ac-f4ad-42c5-ae26-eebd04fe0ada.eszip","externals":[],"functions":[{"name":"ipx","path":"/opt/build/repo/frontend/.netlify/edge-functions/ipx/index.ts"}],"importMapData":"{\"imports\":{\"netlify:edge\":\"https://edge.netlify.com/v1/index.ts\"},\"scopes\":{}}"} (https://ntl.fyi/exit-code-1)
1:38:51 PM: ^
1:38:51 PM:
