Problem:
Edge function is not deployed, even though it works with netlify dev. Likely because local build files created by netlify deploy end up in the wrong directory of the monorepo.
Expected:
- Create monorepo with Expo app as one of the packages (
packages/client). - Add Netlify setup, including an edge function.
- Test setup with
netlify dev. - Deploy with Netlify, and observe the edge function working. ← This step fails.
Observations:
netlify devprints “Loaded edge function hello” and the edge function works.netlify deployprints “Packaging Edge Functions …” as expected, but these are not actually deployed, as is evident when visiting the website or looking at “Deploy summary” in Netlify dashboard.- In
packages/clienta new directory is created bynetlify deploycommand which seems incorrect. This directory is calledpackagesand at pathpackages/client/packages/client/.netlifythere is what looks like something that should’ve been written topackages/client/.netlify. - Adding
base = "packages/client"tonetlify.tomldoes not solve the problem.
Reproduce:
Clone repository https://github.com/santotan/netlifytest and follow instructions in README.md.
- Site name:
https://netlifytest9846.netlify.app/
Local build log
$ netlify deploy --build --prod --filter=client
Netlify Build
❯ Version
@netlify/build 29.51.3
❯ Flags
packagePath: packages/client
❯ Current directory
/Users/st/code/netlifytest/packages/client
❯ Config file
/Users/st/code/netlifytest/packages/client/netlify.toml
❯ Context
production
build.command from netlify.toml
$ expo export -p web --clear
env: load .env
env: export EXPO_USE_METRO_WORKSPACE_ROOT
Starting Metro Bundler
warning: Bundler cache is empty, rebuilding (this may take a minute)
Static rendering is enabled. Learn more: https://docs.expo.dev/router/reference/static-rendering/
Web Bundled 8280ms node_modules/expo-router/entry.js (762 modules)
λ Bundled 8521ms node_modules/expo-router/node/render.js (777 modules)
Exporting 6 static routes:
/ (index) (18.3 kB)
/explore (21.5 kB)
/_sitemap (20.3 kB)
/+not-found (17.5 kB)
/(tabs) (18.3 kB)
/(tabs)/explore (21.5 kB)
Exporting 1 bundle for web:
_expo/static/js/web/entry-c3e42f74fba1d58f1b993e0170f58e75.js (1.43 MB)
Exporting 13 files:
assets/__node_modules/@expo/vector-icons/build/vendor/react-native-vector-icons/Fonts/Ionicons.6148e7019854f3bde85b633cb88f3c25.ttf (443 kB)
assets/__node_modules/@react-navigation/elements/lib/module/assets/back-icon-mask.5223c8d9b0d08b82a5670fb5f71faf78.png (913 B)
assets/__node_modules/@react-navigation/elements/lib/module/assets/back-icon.35ba0eaec5a4f5ed12ca16fabeae451d.png (207 B)
assets/__node_modules/expo-router/assets/error.563d5e3294b67811d0a1aede6f601e30.png (516 B)
assets/__node_modules/expo-router/assets/file.b6c297a501e289394b0bc5dc69c265e6.png (158 B)
assets/__node_modules/expo-router/assets/forward.9d9c5644f55c2f6e4b7f247c378b2fe9.png (250 B)
assets/__node_modules/expo-router/assets/pkg.5974eb3e1c5314e8d5a822702d7d0740.png (429 B)
assets/assets/fonts/SpaceMono-Regular.49a79d66bdea2debf1832bf4d7aca127.ttf (93.3 kB)
assets/assets/images/partial-react-logo.8f14e478886737f3323a2ac79c833749.png (5.08 kB)
assets/assets/images/react-logo.d883906de993aa65bf0ef0d1bc2ff6ad.png (6.34 kB)
assets/assets/images/react-logo.d883906de993aa65bf0ef0d1bc2ff6ad@2x.png (14.2 kB)
assets/assets/images/react-logo.d883906de993aa65bf0ef0d1bc2ff6ad@3x.png (21.3 kB)
favicon.ico (14.5 kB)
App exported to: dist
(build.command completed in 9.9s)
Edge Functions bundling
Packaging Edge Functions from netlify/edge-functions directory:
- hello
(Edge Functions bundling completed in 438ms)
Deploy path: /Users/st/code/netlifytest/packages/client/dist
Configuration path: /Users/st/code/netlifytest/packages/client/netlify.toml
Deploying to main site URL...
⠋ Uploading blobs to deploy store...
Netlify Build
❯ Version
❯ Flags
build: true
deployId: 669e60c5c378a24b954bdb52
filter: client
open: false
prod: true
prodIfUnlocked: false
skipFunctionsCache: false
❯ Current directory
❯ Config file
❯ Context
✔ Finished uploading blobs to deploy store
✔ No cached functions were found
✔ Finished hashing
✔ CDN requesting 0 files
✔ Finished uploading 0 assets
✔ Deploy is live!
Netlify Build Complete
(Netlify Build completed in 15.4s)
