we need to know your netlify site name. Example: pensive-wing-286024.netlify.app
DNS issues? Tell us the custom domain, tell us the error message! antrepernegro.com
Build problems? Link or paste the FULL build log & build settings screenshot
I am having trouble setting up build environment so I can preview website. I am beginning with starter gatsby site and build from there. I am having trouble connecting my github and netlify build configuration so I can view how my site looks on the web.
I can see that there is no build command for this site. If you’re using a Gatsby template, this would be rather odd! You should check what build command the template used and update your own
I am struggling trying to figure out how to set up configuration I was looking to begin with Gatsby starter website and customize from there should I just start over?
