Local build was successful but build at Netlify is not working
I can build my project locally but I can’t do it in Netlify. I hope you can help me with this.
I am using Gatsby.
Below you can find my build details.
Website Domain:
nifty-ptolemy-2e9532.netlify.app
Deploy log link:
Build settings:
Package.json:
“name”: “gatsby-starter-hello-world”,
“private”: true,
“description”: “A simplified bare-bones starter for Gatsby”,
“version”: “0.1.0”,
“license”: “MIT”,
“scripts”: {
“build”: “gatsby build”,
“develop”: “gatsby develop”,
“format”: “prettier --write "**/*.{js,jsx,json,md}"”,
“start”: “npm run develop”,
“serve”: “gatsby serve”,
“clean”: “gatsby clean”,
“test”: “echo "Write tests! → …gatsby.dev/unit-testing" && exit 1”
“dependencies”: {
“@material-ui/core”: “^4.9.11”,
“@material-ui/icons”: “^4.9.1”,
“@material-ui/styles”: “^4.9.10”,
“gatsby”: “^2.19.7”,
“gatsby-plugin-material-ui”: “^2.1.6”,
“gatsby-source-filesystem”: “^2.2.4”,
“gatsby-transformer-remark”: “^2.7.1”,
“react”: “^16.13.1”,
“react-dom”: “^16.12.0”,
“react-redux”: “^7.2.0”,
“redux”: “^4.0.5”
“devDependencies”: {
“prettier”: “^2.0.5”
“repository”: {
“type”: “git”,
“url”: “…/gatsbyjs/gatsby-starter-hello-world”
“bugs”: {
“url”: “…/gatsbyjs/gatsby/issues”
Deploy log:
2:24:04 PM: Build ready to start
2:24:05 PM: build-image version: 2dbd444fcdce00cf06325060a8238d5ae3e86774
2:24:05 PM: build-image tag: v3.3.7
2:24:05 PM: buildbot version: e2864b9f6fb42f8598086b4caa617ac9e650a222
2:24:06 PM: Fetching cached dependencies
2:24:06 PM: Failed to fetch cache, continuing with build
2:24:06 PM: Starting to prepare the repo for build
2:24:06 PM: No cached dependencies found. Cloning fresh repo
2:24:06 PM: git clone ...github.com/ArianKrasniqi/***
2:24:07 PM: Preparing Git Reference refs/heads/master
2:24:08 PM: Starting build script
2:24:08 PM: Installing dependencies
2:24:09 PM: Downloading and installing node v10.20.1...
2:24:09 PM: Downloading ...nodejs.org/dist/v10.20.1/node-v10.20.1-linux-x64.tar.xz...
2:24:09 PM: ##################################
2:24:09 PM: 48.0%
2:24:10 PM: ###############################
2:24:10 PM: ######################################### 100.0%
2:24:10 PM: Computing checksum with sha256sum
2:24:10 PM: Checksums matched!
2:24:12 PM: Now using node v10.20.1 (npm v6.14.4)
2:24:12 PM: Attempting ruby version 2.6.2, read from environment
2:24:13 PM: Using ruby version 2.6.2
2:24:13 PM: Using PHP version 5.6
2:24:13 PM: Started restoring cached node modules
2:24:13 PM: Finished restoring cached node modules
2:24:14 PM: Installing NPM modules using NPM version 6.14.4
2:24:41 PM: > core-js@2.6.11 postinstall /opt/build/repo/node_modules/core-js
2:24:41 PM: > node -e "try{require('./postinstall')}catch(e){}"
2:24:41 PM: Thank you for using core-js ( ... ) for polyfilling JavaScript standard library!
2:24:41 PM: The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
2:24:41 PM: > ...opencollective.com/core-js...
2:24:41 PM: > ...patreon.com/zloirock...
2:24:41 PM: Also, the author of core-js ( ...github.com/zloirock... ) is looking for a good job -)
2:24:41 PM: > ...core-js-pure@3.6.4 postinstall /opt/build/repo/node_modules/core-js-pure...
2:24:41 PM: > gatsby-telemetry@1.1.55 postinstall /opt/build/repo/node_modules/gatsby-telemetry
2:24:41 PM: > node src/postinstall.js || true
2:24:41 PM: > gatsby-cli@2.10.9 postinstall /opt/build/repo/node_modules/gatsby/node_modules/gatsby-cli
2:24:41 PM: > node scripts/postinstall.js
2:24:41 PM: > gatsby@2.19.41 postinstall /opt/build/repo/node_modules/gatsby
2:24:43 PM: npm WARN
2:24:43 PM: optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
2:24:43 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
2:24:43 PM: npm
2:24:43 PM: WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/gatsby-source-filesystem/node_modules/fsevents):
2:24:43 PM: npm
2:24:43 PM: WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
2:24:43 PM: optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/chokidar/node_modules/fsevents):
2:24:43 PM: SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
2:24:43 PM: added 1858 packages from 770 contributors and audited 24160 packages in 29.041s
2:24:45 PM: 107 packages are looking for funding
2:24:45 PM: run `npm fund` for details
2:24:45 PM: found 31 low severity vulnerabilities
2:24:45 PM: run `npm audit fix` to fix them, or `npm audit` for details
2:24:45 PM: NPM modules installed
2:24:45 PM: Started restoring cached go cache
2:24:45 PM: Finished restoring cached go cache
2:24:45 PM: unset GOOS;
2:24:45 PM: unset GOARCH;
2:24:45 PM: export GOROOT='/opt/buildhome/.gimme/versions/go1.12.linux.amd64';
2:24:45 PM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
2:24:45 PM: go version >&2;
2:24:45 PM: export GIMME_ENV='/opt/buildhome/.gimme/env/go1.12.linux.amd64.env';
2:24:45 PM: go version go1.12 linux/amd64
2:24:45 PM: Installing missing commands
2:24:45 PM: Verify run directory
2:24:45 PM: Executing user command: gatsby build
2:24:47 PM: success open and validate gatsby-configs - 0.023s
2:24:47 PM: success load plugins - 0.329s
2:24:47 PM: success onPreInit - 0.010s
2:24:48 PM: success delete html and css files from previous builds - 0.013s
2:24:48 PM: success initialize cache - 0.008s
2:24:48 PM: success copy gatsby files - 0.027s
2:24:48 PM: success onPreBootstrap - 0.003s
2:24:48 PM: success createSchemaCustomization - 0.005s
2:24:48 PM: success source and transform nodes - 0.925s
2:24:49 PM: success building schema - 0.266s
2:24:49 PM: success createPages - 0.234s
2:24:49 PM: success createPagesStatefully - 0.054s
2:24:49 PM: success onPreExtractQueries - 0.000s
2:24:49 PM: success update schema - 0.040s
2:24:49 PM: success extract queries from components - 0.194s
2:24:49 PM: success write out requires - 0.009s
2:24:49 PM: success write out redirect data - 0.001s
2:24:49 PM: success onPostBootstrap - 0.000s
2:24:49 PM: ⠀
2:24:49 PM: info bootstrap finished - 4.131 s
2:24:49 PM: ⠀
2:25:37 PM: warning chunk styles [mini-css-extract-plugin]
2:25:37 PM: Conflicting order. Following module has been added:
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/elements/Input/Input.module.css
2:25:37 PM: despite it was not able to fulfill desired ordering with these modules:
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/elements/Text/Text.module.css (1)
2:25:37 PM: - couldn't fulfill desired order of chunk group(s) component---src-pages-krankenkasse-js, component---src-templates-information-js, component---src-pages-beratung-anfordern-js, component---src-pages-index-js, component---src-pages-kontakt-js, component---src-pages-praemienrechner-js
2:25:37 PM: - while fulfilling desired order of chunk group(s) component---src-templates-company-js
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Cover/Cover.module.css
2:25:37 PM: - couldn't fulfill desired order of chunk group(s) component---src-pages-index-js
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Cover/Buttons/Buttons.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/elements/Link/Link.module.css
2:25:37 PM: - while fulfilling desired order of chunk group(s) component---src-pages-krankenkasse-js
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Lists/List/List.module.css
2:25:37 PM: - couldn't fulfill desired order of chunk group(s) component---src-templates-glossar-js
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Lists/Lists.module.css
2:25:37 PM: - couldn't fulfill desired order of chunk group(s) component---src-pages-index-js, component---src-pages-informationen-js
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/CompareForm/Price/Price.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/CompareForm/Franchise/Franchise.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/CompareForm/CompareInputs/CompareInputs.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/ContactForm/PregnancyInputs/Inputs.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/Compare.module.css
2:25:37 PM: - couldn't fulfill desired order of chunk group(s) component---src-templates-information-js
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/CompareForm/CompareForm.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/ContactForm/ContactInputs/Inputs.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref--12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/ContactForm/ContactForm.module.css
2:25:37 PM: - while fulfilling desired order of chunk group(s) component---src-pages-index-js
2:25:37 PM: failed Building production JavaScript and CSS bundles - 47.224s
2:25:37 PM: error Generating JavaScript bundles failed
2:25:37 PM: Can't resolve '../../../../elements/Button/Button' in '/opt/build/repo/src/components/Compare/CompareForm/CompareInputs'
2:25:37 PM: Can't resolve '../../../elements/Button/Button' in '/opt/build/repo/src/components/ContactCompany/Inputs'
2:25:37 PM: Can't resolve '../../../elements/Button/Button' in '/opt/build/repo/src/components/ContactForm/ContactInputs'
2:25:37 PM: Can't resolve '../../../elements/Button/Button' in '/opt/build/repo/src/components/ContactForm/PregnancyInputs'
2:25:37 PM: Can't resolve '../../../elements/Button/Button' in '/opt/build/repo/src/components/SideForm/SideFormInputs'
2:25:37 PM: Can't resolve '../../elements/Button/Button' in '/opt/build/repo/src/components/Compare'
2:25:37 PM: Can't resolve '../Button/Button' in '/opt/build/repo/src/elements/RightCard'
2:25:37 PM: Can't resolve '../components/Layout/Layout' in '/opt/build/repo/src/pages'
2:25:37 PM: Can't resolve '../components/Layout/Layout' in '/opt/build/repo/src/templates'
2:25:37 PM: Can't resolve './informationCard.module.css' in '/opt/build/repo/src/components/ContactCompany/InformationCard'
2:25:37 PM: not finished run queries - 47.301s
2:25:37 PM: Skipping functions preparation step: no functions directory set
2:25:37 PM: Caching artifacts
2:25:37 PM: Started saving node modules
2:25:37 PM: Finished saving node modules
2:25:37 PM: Started saving pip cache
2:25:37 PM: Finished saving pip cache
2:25:37 PM: Started saving emacs cask dependencies
2:25:37 PM: Finished saving emacs cask dependencies
2:25:37 PM: Started saving maven dependencies
2:25:37 PM: Finished saving maven dependencies
2:25:37 PM: Started saving boot dependencies
2:25:37 PM: Finished saving boot dependencies
2:25:37 PM: Started saving go dependencies
2:25:37 PM: Finished saving go dependencies
2:25:41 PM: Error running command: Build script returned non-zero exit code: 1
2:25:41 PM: Failing build: Failed to build site
2:25:41 PM: failed during stage 'building site': Build script returned non-zero exit code: 1
2:25:41 PM: Finished processing build request in 1m35.51108783s
Hi there, thanks for that! I know the log output is a little hard to read, but here is where the big problem begins:
If you look at the paths you will see things like Layout/Layout and Button/Button which looks like paths are always duplicated. I am not sure why exactly this is, but this may be part of the problem.
Frequently, when customers report that things work locally but fail on deploy it is actually an issue with case:
