Deploy log:
2:24:04 PM: Build ready to start
2:24:05 PM: build-image version: 2dbd444fcdce00cf06325060a8238d5ae3e86774
2:24:05 PM: build-image tag: v3.3.7
2:24:05 PM: buildbot version: e2864b9f6fb42f8598086b4caa617ac9e650a222
2:24:06 PM: Fetching cached dependencies
2:24:06 PM: Failed to fetch cache, continuing with build
2:24:06 PM: Starting to prepare the repo for build
2:24:06 PM: No cached dependencies found. Cloning fresh repo
2:24:06 PM: git clone …github.com/ArianKrasniqi/***
2:24:07 PM: Preparing Git Reference refs/heads/master
2:24:08 PM: Starting build script
2:24:08 PM: Installing dependencies
2:24:09 PM: Downloading and installing node v10.20.1…
2:24:09 PM: Downloading …nodejs.org/dist/v10.20.1/node-v10.20.1-linux-x64.tar.xz…
2:24:09 PM: ##################################
2:24:09 PM: 48.0%
2:24:10 PM: ###############################
2:24:10 PM: ######################################### 100.0%
2:24:10 PM: Computing checksum with sha256sum
2:24:10 PM: Checksums matched!
2:24:12 PM: Now using node v10.20.1 (npm v6.14.4)
2:24:12 PM: Attempting ruby version 2.6.2, read from environment
2:24:13 PM: Using ruby version 2.6.2
2:24:13 PM: Using PHP version 5.6
2:24:13 PM: Started restoring cached node modules
2:24:13 PM: Finished restoring cached node modules
2:24:14 PM: Installing NPM modules using NPM version 6.14.4
2:24:41 PM: > core-js@2.6.11 postinstall /opt/build/repo/node_modules/core-js
2:24:41 PM: > node -e “try{require(’./postinstall’)}catch(e){}”
2:24:41 PM: Thank you for using core-js ( … ) for polyfilling JavaScript standard library!
2:24:41 PM: The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
2:24:41 PM: > …opencollective.com/core-js…
2:24:41 PM: > …patreon.com/zloirock…
2:24:41 PM: Also, the author of core-js ( …github.com/zloirock… ) is looking for a good job -)
2:24:41 PM: > …core-js-pure@3.6.4 postinstall /opt/build/repo/node_modules/core-js-pure…
2:24:41 PM: > gatsby-telemetry@1.1.55 postinstall /opt/build/repo/node_modules/gatsby-telemetry
2:24:41 PM: > node src/postinstall.js || true
2:24:41 PM: > gatsby-cli@2.10.9 postinstall /opt/build/repo/node_modules/gatsby/node_modules/gatsby-cli
2:24:41 PM: > node scripts/postinstall.js
2:24:41 PM: > gatsby@2.19.41 postinstall /opt/build/repo/node_modules/gatsby
2:24:43 PM: npm WARN
2:24:43 PM: optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.11 (node_modules/fsevents):
2:24:43 PM: npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.11: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
2:24:43 PM: npm
2:24:43 PM: WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/gatsby-source-filesystem/node_modules/fsevents):
2:24:43 PM: npm
2:24:43 PM: WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
2:24:43 PM: optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/chokidar/node_modules/fsevents):
2:24:43 PM: SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
2:24:43 PM: added 1858 packages from 770 contributors and audited 24160 packages in 29.041s
2:24:45 PM: 107 packages are looking for funding
2:24:45 PM: run npm fund for details
2:24:45 PM: found 31 low severity vulnerabilities
2:24:45 PM: run npm audit fix to fix them, or npm audit for details
2:24:45 PM: NPM modules installed
2:24:45 PM: Started restoring cached go cache
2:24:45 PM: Finished restoring cached go cache
2:24:45 PM: unset GOOS;
2:24:45 PM: unset GOARCH;
2:24:45 PM: export GOROOT=’/opt/buildhome/.gimme/versions/go1.12.linux.amd64’;
2:24:45 PM: export PATH="/opt/buildhome/.gimme/versions/go1.12.linux.amd64/bin:${PATH}";
2:24:45 PM: go version >&2;
2:24:45 PM: export GIMME_ENV=’/opt/buildhome/.gimme/env/go1.12.linux.amd64.env’;
2:24:45 PM: go version go1.12 linux/amd64
2:24:45 PM: Installing missing commands
2:24:45 PM: Verify run directory
2:24:45 PM: Executing user command: gatsby build
2:24:47 PM: success open and validate gatsby-configs - 0.023s
2:24:47 PM: success load plugins - 0.329s
2:24:47 PM: success onPreInit - 0.010s
2:24:48 PM: success delete html and css files from previous builds - 0.013s
2:24:48 PM: success initialize cache - 0.008s
2:24:48 PM: success copy gatsby files - 0.027s
2:24:48 PM: success onPreBootstrap - 0.003s
2:24:48 PM: success createSchemaCustomization - 0.005s
2:24:48 PM: success source and transform nodes - 0.925s
2:24:49 PM: success building schema - 0.266s
2:24:49 PM: success createPages - 0.234s
2:24:49 PM: success createPagesStatefully - 0.054s
2:24:49 PM: success onPreExtractQueries - 0.000s
2:24:49 PM: success update schema - 0.040s
2:24:49 PM: success extract queries from components - 0.194s
2:24:49 PM: success write out requires - 0.009s
2:24:49 PM: success write out redirect data - 0.001s
2:24:49 PM: success onPostBootstrap - 0.000s
2:24:49 PM: ?
2:24:49 PM: info bootstrap finished - 4.131 s
2:24:49 PM: ?
2:25:37 PM: warning chunk styles [mini-css-extract-plugin]
2:25:37 PM: Conflicting order. Following module has been added:
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/elements/Input/Input.module.css
2:25:37 PM: despite it was not able to fulfill desired ordering with these modules:
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/elements/Text/Text.module.css (1)
2:25:37 PM: - couldn’t fulfill desired order of chunk group(s) component—src-pages-krankenkasse-js, component—src-templates-information-js, component—src-pages-beratung-anfordern-js, component—src-pages-index-js, component—src-pages-kontakt-js, component—src-pages-praemienrechner-js
2:25:37 PM: - while fulfilling desired order of chunk group(s) component—src-templates-company-js
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Cover/Cover.module.css
2:25:37 PM: - couldn’t fulfill desired order of chunk group(s) component—src-pages-index-js
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Cover/Buttons/Buttons.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/elements/Link/Link.module.css
2:25:37 PM: - while fulfilling desired order of chunk group(s) component—src-pages-krankenkasse-js
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Lists/List/List.module.css
2:25:37 PM: - couldn’t fulfill desired order of chunk group(s) component—src-templates-glossar-js
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Lists/Lists.module.css
2:25:37 PM: - couldn’t fulfill desired order of chunk group(s) component—src-pages-index-js, component—src-pages-informationen-js
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/CompareForm/Price/Price.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/CompareForm/Franchise/Franchise.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/CompareForm/CompareInputs/CompareInputs.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/ContactForm/PregnancyInputs/Inputs.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/Compare.module.css
2:25:37 PM: - couldn’t fulfill desired order of chunk group(s) component—src-templates-information-js
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/Compare/CompareForm/CompareForm.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/ContactForm/ContactInputs/Inputs.module.css
2:25:37 PM: * css ./node_modules/css-loader??ref–12-oneOf-0-1!./node_modules/postcss-loader/src??postcss-1!./src/components/ContactForm/ContactForm.module.css
2:25:37 PM: - while fulfilling desired order of chunk group(s) component—src-pages-index-js
2:25:37 PM: failed Building production JavaScript and CSS bundles - 47.224s
2:25:37 PM: error Generating JavaScript bundles failed
2:25:37 PM: Can’t resolve ‘…/…/…/…/elements/Button/Button’ in ‘/opt/build/repo/src/components/Compare/CompareForm/CompareInputs’
2:25:37 PM: Can’t resolve ‘…/…/…/elements/Button/Button’ in ‘/opt/build/repo/src/components/ContactCompany/Inputs’
2:25:37 PM: Can’t resolve ‘…/…/…/elements/Button/Button’ in ‘/opt/build/repo/src/components/ContactForm/ContactInputs’
2:25:37 PM: Can’t resolve ‘…/…/…/elements/Button/Button’ in ‘/opt/build/repo/src/components/ContactForm/PregnancyInputs’
2:25:37 PM: Can’t resolve ‘…/…/…/elements/Button/Button’ in ‘/opt/build/repo/src/components/SideForm/SideFormInputs’
2:25:37 PM: Can’t resolve ‘…/…/elements/Button/Button’ in ‘/opt/build/repo/src/components/Compare’
2:25:37 PM: Can’t resolve ‘…/Button/Button’ in ‘/opt/build/repo/src/elements/RightCard’
2:25:37 PM: Can’t resolve ‘…/components/Layout/Layout’ in ‘/opt/build/repo/src/pages’
2:25:37 PM: Can’t resolve ‘…/components/Layout/Layout’ in ‘/opt/build/repo/src/templates’
2:25:37 PM: Can’t resolve ‘./informationCard.module.css’ in ‘/opt/build/repo/src/components/ContactCompany/InformationCard’
2:25:37 PM: not finished run queries - 47.301s
2:25:37 PM: Skipping functions preparation step: no functions directory set
2:25:37 PM: Caching artifacts
2:25:37 PM: Started saving node modules
2:25:37 PM: Finished saving node modules
2:25:37 PM: Started saving pip cache
2:25:37 PM: Finished saving pip cache
2:25:37 PM: Started saving emacs cask dependencies
2:25:37 PM: Finished saving emacs cask dependencies
2:25:37 PM: Started saving maven dependencies
2:25:37 PM: Finished saving maven dependencies
2:25:37 PM: Started saving boot dependencies
2:25:37 PM: Finished saving boot dependencies
2:25:37 PM: Started saving go dependencies
2:25:37 PM: Finished saving go dependencies
2:25:41 PM: Error running command: Build script returned non-zero exit code: 1
2:25:41 PM: Failing build: Failed to build site
2:25:41 PM: failed during stage ‘building site’: Build script returned non-zero exit code: 1
2:25:41 PM: Finished processing build request in 1m35.51108783s
