Hi there, I was trying to get my personal website to work, at first when I deployed it manually it worked just fine and all the styles were applying, although I made the switch to github repo as I’m using git in vs code to push changes, when I did this the tailwind styles don’t apply anymore
the folder structer is
-root
tailwind config
-src
//all public .html
-node_modules
-dist
-assets
and my deploy setting are:
“base directory” : /
“package directory” : not set
“build command” : not set
“publish directory” : /src
the domani is fil-design.it
Thank you all!
