Sls problem and confusion
Hi Netlify Support team,
My site dashboard correctly shows only alhilalpedia.com under Production Domains. However, the Let’s Encrypt section is stuck trying to renew a certificate that bundles an accidental typo domain (salhilalpedia.com) which I do not own.
Because the background system is attempting to validate both names at once, the SSL provisioning process is blocked with a “not served by Netlify” error.
Could an administrator please manually clear or flush the old certificate history/metadata for this site project so I can provision a clean SSL certificate exclusively for alhilalpedia.com?
Thank you!
hey @Megdad thanks for getting in touch and apologies for the delay! I’ve manually renewed this certificate on our end, and you should be good to go moving forward. Let us know if there’s anything else we can assist with.
