Hello, as others, I am facing very slow load times for static assets (images). Respectfully, as there seem to be several of these issues with Netlify, even though the UX is good, I registered to try out the performance which is #1 for my criteria… so I’m probably moving to another provider. But I thought it’s worth a shot in case I have something wrong in my setup (although I’m just using the Netlify DNS). Here’s the debug info you need:
Trying “www.gplus.gr”
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 64872
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 0
;; QUESTION SECTION:
;www.gplus.gr. IN A
;; ANSWER SECTION:
www.gplus.gr. 19 IN A 142.93.108.123
Received 46 bytes from 8.8.8.8#53 in 58 ms
Trying "www.gplus.gr"
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 3154
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
;www.gplus.gr. IN AAAA
;; AUTHORITY SECTION:
gplus.gr. 1799 IN SOA dns1.p07.nsone.net. domains+netlify.netlify.com. 1588072725 43200 7200 1209600 3600
Received 111 bytes from 8.8.8.8#53 in 42 ms
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 38924
;www.gplus.gr. IN MX
Received 111 bytes from 8.8.8.8#53 in 62 ms
x-nf-request-id:e733b40d-7586-4c2e-83ba-a3a6b3b7bd11-21231359
Here’s the HAR: Deleted
