Setting up CICD using external tools
  • We need to know your netlify site name. Example: gifted-antelope-58b104.netlify.app
  • DNS issues? Tell us the custom domain, tell us the error message! We can’t help if we don’t know your domain.
  • Build problems? Link or paste the FULL build log & build settings screenshot
  • Did you try Ask Netlify, our generative AI chatbot, before posting? It pulls info from Support Guides and recent solved forums posts.
Site name - gurdipdev
Hi,
This is a simple question. I use CICD (TeamCity/Octopus). I am a little confused on one thing. I want to have a dev site to test deployments, alongside my production site. Do I need a seperate site? I notice the deployment command has a --prod flag I believe.
Also, how does this work when the working directory on my CI gets checked out an deleted?
You don’t need a separate site, but depending on your requirements, it might or might not make sense to have one. It’s for you to decide.
Once the site is deployed, it doesn’t matter if your working directory is deleted.
