I am in the middle of setting up a custom domain name for a Netlify deploy. I’m using Google Domains which doesn’t support ANAME or ALIAS records, only A record. Because of this, I am forced to use the A record.
In the Netlify UI, there’s a warning when using A records:
I don’t understand the warning, that is, the ramifications of using an A record. Will this detract from anything or affect how my site is rendered/deployed? What are the actual impacts that I might occur if I go this route?
Thanks in advance,
