Having issues with adding required to input fields and using netlify forms. It appears that netlify put the whole form inside its name="form-name" element but this then means you have hidden fields that are required, which the browser doesn’t like. An invalid form control with name='email' is not focusable. <input type="email" name="email" required="required" class="block w-full p-2 rounded-md text-redDark bg-white"> is the error from chrome browser when trying to submit the form.
Using nuxt so unsure if that is causing the issues, however its set to static deployment so its generating HTML files so I don’t think this would where the issue is.
