Renewals of SSL Certificate does not work
Hi,
I get an error when Netlify tries to autorenew the SSL certificate:
SniCertificate::CertificateNonvalidError: Unable to verify challenge for 360x.art
The DNS is setup correclty from our site. What else is there I can do, to make it work again?
Netlify site: cocky-cori-cb04c1.netlify.app
According to the Troubleshooting guide I should post here in order to get the certificate fixed.
Thanks in advance.
:wave: @gliesche ,
It appears you have DNS records configured for both Netlify and Google. You’ll need to remove the A record 34.102.136.180:
% host 360x.art
360x.art has address 34.102.136.180
360x.art has address 75.2.60.5
Also, you’ve exceeded Let’s Encrypt rate limits and will need to wait a week before we can retry renewing SSL cert. You can install a custom cert in the meantime as I see your cert expires tomorrow.
