Hello! Redirects are not work, when we try to manually redirect from url with slash in the end to same url without slash. Like from /test/ to /test. Is there solution how to do this?
If you have a setup in the following manner: /test/index.html
, and you want the file to be available at /test
, it won’t work perfectly. Sometimes (if not always), the page would return a 404. The configuration is possible when you have the setup like: /test.html
. This can be made possible using Asset Optimization feature.
There might be a possibility that you can configure the generation of pages in your Static Site Generator (if you use one).
