React deployed blank screen problem
I just started learning react and recently just built my first react application using create-react-app, it’s production build runs perfectly on my system locally but when i deployed it on netlify it keeps giving me a blank screen, please can someone help with this. Link to repo GitHub - Nosa-Drexx/Tic-Tac-Toe-Reactjs-
have you looked at the console or network tab in your browser? I would guess you might be running into some CORs errors.
This seems to be the site: https://deft-blancmange-b0fdef.netlify.app/
There are a few errors in your app and the console points to the exact lines where you need to fix those:
Thanks a lot this was the exact problem … didn’t even think of checking the console, :pensive: but i am still confused though when i ran it locally my console didn’t throw off any error, why then did it have that error after deploying
Thanks alot the error was right there on the console . Really appreciate.
Glad everything is working now, @nosa! Happy building :netliconfetti:
