Hi,
I have a problem I can make my domain work using A name and C name settings, not sure if I am using the correct ones., does any one know how I should fix this?
Hi,
@Lexero I don’t understand your post due to how it is phrased.
What is your issue?
If it’s DNS configuration related, what is the domain?
I already found the solution, there was a spelling misstake in the Cmane entry at the domain provider.
Great, glad you were able to get it sorted.
