Problems with deploy
Hello! I have some issues with deploying my react site soft-kleicha-3be3fc.netlify.app.
May I ask for help please? Thank you!
This is the deploy log (last couple of lines):
11:37:32 AM: Error during NPM install
11:37:32 AM: Build was terminated: Build script returned non-zero exit code: 1
11:37:33 AM: Creating deploy upload records
11:37:33 AM: Failing build: Failed to build site
11:37:33 AM: Failed during stage 'building site': Build script returned non-zero exit code: 1 (https://ntl.fyi/exit-code-1)
11:37:33 AM: Finished processing build request in 3m10.161805882s
@angelangweihan The lines that you’ve provided don’t show the cause of the error.
If above those lines it mentions peer dependencies then you could try this answer:
Ahh sorry, I’ll include the rest of the log here:
11:34:15 AM: Build ready to start
11:34:23 AM: build-image version: 0e2f4c52031ab562db66aec633308326e3b108d0 (focal)
11:34:23 AM: build-image tag: focal
11:34:23 AM: buildbot version: ed990b4b6588208e959ba45b6b7b05738f8b6004
11:34:23 AM: Fetching cached dependencies
11:34:23 AM: Failed to fetch cache, continuing with build
11:34:23 AM: Starting to prepare the repo for build
11:34:23 AM: No cached dependencies found. Cloning fresh repo
11:34:23 AM: git clone https://github.com/angelangweihan/website-interactive
11:34:24 AM: Preparing Git Reference refs/heads/main
11:34:24 AM: Parsing package.json dependencies
11:34:26 AM: Starting build script
11:34:26 AM: Installing dependencies
11:34:26 AM: Python version set to 2.7
11:34:26 AM: Downloading and installing node v16.16.0...
11:34:27 AM: Downloading https://nodejs.org/dist/v16.16.0/node-v16.16.0-linux-x64.tar.xz...
11:34:27 AM: Computing checksum with sha256sum
11:34:27 AM: Checksums matched!
11:34:30 AM: Now using node v16.16.0 (npm v8.11.0)
11:34:30 AM: Started restoring cached build plugins
11:34:30 AM: Finished restoring cached build plugins
11:34:30 AM: Attempting ruby version 2.7.2, read from environment
11:34:31 AM: Using ruby version 2.7.2
11:34:31 AM: Using PHP version 8.0
11:34:32 AM: No npm workspaces detected
11:34:32 AM: Started restoring cached node modules
11:34:32 AM: Finished restoring cached node modules
11:34:32 AM: Installing NPM modules using NPM version 8.11.0
11:34:33 AM: npm WARN config tmp This setting is no longer used.  npm stores temporary files in a special
11:34:33 AM: npm WARN config location in the cache, and they are managed by
11:34:33 AM: npm WARN config     [`cacache`](http://npm.im/cacache).
11:34:34 AM: npm WARN old lockfile
11:34:34 AM: npm WARN old lockfile The package-lock.json file was created with an old version of npm,
11:34:34 AM: npm WARN old lockfile so supplemental metadata must be fetched from the registry.
11:34:34 AM: npm WARN old lockfile This is a one-time fix-up, please be patient...
11:34:55 AM: npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
11:34:56 AM: npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
11:34:56 AM: npm WARN deprecated har-validator@5.1.5: this library is no longer supported
11:34:56 AM: npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
11:34:56 AM: npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
11:34:57 AM: npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
11:34:58 AM: npm WARN deprecated stable@0.1.8: Modern JS already guarantees Array#sort() is a stable sort, so this library is deprecated. See the compatibility table on MDN: https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/Array/sort#browser_compatibility
11:34:58 AM: npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
11:34:59 AM: npm WARN deprecated request-promise-native@1.0.9: request-promise-native has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
11:34:59 AM: npm WARN deprecated sane@4.1.0: some dependency vulnerabilities fixed, support for node < 10 dropped, and newer ECMAScript syntax/features added
11:35:00 AM: npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
11:35:02 AM: npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
11:35:04 AM: npm WARN deprecated flatten@1.0.3: flatten is deprecated in favor of utility frameworks such as lodash.
11:35:05 AM: npm WARN deprecated html-webpack-plugin@4.0.0-beta.5: please switch to a stable version
11:35:05 AM: npm WARN deprecated eslint-loader@3.0.2: This loader has been deprecated. Please use eslint-webpack-plugin
11:35:07 AM: npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
11:35:08 AM: npm WARN deprecated babel-eslint@10.0.3: babel-eslint is now @babel/eslint-parser. This package will no longer receive updates.
11:35:08 AM: npm WARN deprecated svgo@1.3.2: This SVGO version is no longer supported. Upgrade to v2.x.x.
11:35:09 AM: npm WARN deprecated @hapi/topo@3.1.6: This version has been deprecated and is no longer supported or maintained
11:35:09 AM: npm WARN deprecated @hapi/bourne@1.3.2: This version has been deprecated and is no longer supported or maintained
11:35:10 AM: npm WARN deprecated @hapi/address@2.1.4: Moved to 'npm install @sideway/address'
11:35:11 AM: npm WARN deprecated @hapi/hoek@8.5.1: This version has been deprecated and is no longer supported or maintained
11:35:13 AM: npm WARN deprecated axios@0.19.2: Critical security vulnerability fixed in v0.21.1. For more information, see https://github.com/axios/axios/pull/3410
11:35:13 AM: npm WARN deprecated @hapi/joi@15.1.1: Switch to 'npm install joi'
11:35:14 AM: npm WARN deprecated tar@2.2.2: This version of tar is no longer supported, and will not receive security updates. Please upgrade asap.
11:35:19 AM: npm WARN deprecated core-js@2.6.12: core-js@<3.23.3 is no longer maintained and not recommended for usage due to the number of issues. Because of the V8 engine whims, feature detection in old core-js versions could cause a slowdown up to 100x even if nothing is polyfilled. Some versions have web compatibility issues. Please, upgrade your dependencies to the actual version of core-js.
11:37:32 AM: npm ERR! code 1
11:37:32 AM: npm ERR! path /opt/build/repo/node_modules/node-sass
11:37:32 AM: npm ERR! command failed
11:37:32 AM: npm ERR! command sh -c node scripts/build.js
11:37:32 AM: npm ERR! Building: /opt/buildhome/.nvm/versions/node/v16.16.0/bin/node /opt/build/repo/node_modules/node-gyp/bin/node-gyp.js rebuild --verbose --libsass_ext= --libsass_cflags= --libsass_ldflags= --libsass_library=
11:37:32 AM: npm ERR! make: Entering directory '/opt/build/repo/node_modules/node-sass/build'
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/ast.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/ast.o ../src/libsass/src/ast.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/ast_fwd_decl.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/ast_fwd_decl.o ../src/libsass/src/ast_fwd_decl.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/backtrace.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/backtrace.o ../src/libsass/src/backtrace.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/base64vlq.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/base64vlq.o ../src/libsass/src/base64vlq.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/bind.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/bind.o ../src/libsass/src/bind.cpp
11:37:32 AM: npm ERR!   cc '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer  -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/cencode.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/cencode.o ../src/libsass/src/cencode.c
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/check_nesting.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/check_nesting.o ../src/libsass/src/check_nesting.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/color_maps.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/color_maps.o ../src/libsass/src/color_maps.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/constants.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/constants.o ../src/libsass/src/constants.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/context.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/context.o ../src/libsass/src/context.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/cssize.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/cssize.o ../src/libsass/src/cssize.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/emitter.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/emitter.o ../src/libsass/src/emitter.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/environment.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/environment.o ../src/libsass/src/environment.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/error_handling.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/error_handling.o ../src/libsass/src/error_handling.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/eval.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/eval.o ../src/libsass/src/eval.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/expand.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/expand.o ../src/libsass/src/expand.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/extend.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/extend.o ../src/libsass/src/extend.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/file.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/file.o ../src/libsass/src/file.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/functions.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/functions.o ../src/libsass/src/functions.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/inspect.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/inspect.o ../src/libsass/src/inspect.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/json.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/json.o ../src/libsass/src/json.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/lexer.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/lexer.o ../src/libsass/src/lexer.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/listize.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/listize.o ../src/libsass/src/listize.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/memory/SharedPtr.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/memory/SharedPtr.o ../src/libsass/src/memory/SharedPtr.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/node.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/node.o ../src/libsass/src/node.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/operators.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/operators.o ../src/libsass/src/operators.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/output.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/output.o ../src/libsass/src/output.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/parser.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/parser.o ../src/libsass/src/parser.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/plugins.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/plugins.o ../src/libsass/src/plugins.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/position.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/position.o ../src/libsass/src/position.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/prelexer.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/prelexer.o ../src/libsass/src/prelexer.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/remove_placeholders.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/remove_placeholders.o ../src/libsass/src/remove_placeholders.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/sass.o ../src/libsass/src/sass.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass2scss.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/sass2scss.o ../src/libsass/src/sass2scss.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass_context.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/sass_context.o ../src/libsass/src/sass_context.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass_functions.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/sass_functions.o ../src/libsass/src/sass_functions.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass_util.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/sass_util.o ../src/libsass/src/sass_util.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass_values.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/sass_values.o ../src/libsass/src/sass_values.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/source_map.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/source_map.o ../src/libsass/src/source_map.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/subset_map.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/subset_map.o ../src/libsass/src/subset_map.cpp
npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/to_c.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/to_c.o ../src/libsass/src/to_c.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/to_value.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/to_value.o ../src/libsass/src/to_value.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/units.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/units.o ../src/libsass/src/units.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/utf8_string.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/utf8_string.o ../src/libsass/src/utf8_string.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/util.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/util.o ../src/libsass/src/util.cpp
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/values.o.d.raw   -c -o Release/obj.target/libsass/src/libsass/src/values.o ../src/libsass/src/values.cpp
11:37:32 AM: npm ERR!   rm -f Release/obj.target/src/sass.a && ar crs Release/obj.target/src/sass.a Release/obj.target/libsass/src/libsass/src/ast.o Release/obj.target/libsass/src/libsass/src/ast_fwd_decl.o Release/obj.target/libsass/src/libsass/src/backtrace.o Release/obj.target/libsass/src/libsass/src/base64vlq.o Release/obj.target/libsass/src/libsass/src/bind.o Release/obj.target/libsass/src/libsass/src/cencode.o Release/obj.target/libsass/src/libsass/src/check_nesting.o Release/obj.target/libsass/src/libsass/src/color_maps.o Release/obj.target/libsass/src/libsass/src/constants.o Release/obj.target/libsass/src/libsass/src/context.o Release/obj.target/libsass/src/libsass/src/cssize.o Release/obj.target/libsass/src/libsass/src/emitter.o Release/obj.target/libsass/src/libsass/src/environment.o Release/obj.target/libsass/src/libsass/src/error_handling.o Release/obj.target/libsass/src/libsass/src/eval.o Release/obj.target/libsass/src/libsass/src/expand.o Release/obj.target/libsass/src/libsass/src/extend.o Release/obj.target/libsass/src/libsass/src/file.o Release/obj.target/libsass/src/libsass/src/functions.o Release/obj.target/libsass/src/libsass/src/inspect.o Release/obj.target/libsass/src/libsass/src/json.o Release/obj.target/libsass/src/libsass/src/lexer.o Release/obj.target/libsass/src/libsass/src/listize.o Release/obj.target/libsass/src/libsass/src/memory/SharedPtr.o Release/obj.target/libsass/src/libsass/src/node.o Release/obj.target/libsass/src/libsass/src/operators.o Release/obj.target/libsass/src/libsass/src/output.o Release/obj.target/libsass/src/libsass/src/parser.o Release/obj.target/libsass/src/libsass/src/plugins.o Release/obj.target/libsass/src/libsass/src/position.o Release/obj.target/libsass/src/libsass/src/prelexer.o Release/obj.target/libsass/src/libsass/src/remove_placeholders.o Release/obj.target/libsass/src/libsass/src/sass.o Release/obj.target/libsass/src/libsass/src/sass2scss.o Release/obj.target/libsass/src/libsass/src/sass_context.o Release/obj.target/libsass/src/libsass/src/sass_functions.o Release/obj.target/libsass/src/libsass/src/sass_util.o Release/obj.target/libsass/src/libsass/src/sass_values.o Release/obj.target/libsass/src/libsass/src/source_map.o Release/obj.target/libsass/src/libsass/src/subset_map.o Release/obj.target/libsass/src/libsass/src/to_c.o Release/obj.target/libsass/src/libsass/src/to_value.o Release/obj.target/libsass/src/libsass/src/units.o Release/obj.target/libsass/src/libsass/src/utf8_string.o Release/obj.target/libsass/src/libsass/src/util.o Release/obj.target/libsass/src/libsass/src/values.o
11:37:32 AM: npm ERR!   rm -rf "Release/sass.a" && cp -af "Release/obj.target/src/sass.a" "Release/sass.a"
11:37:32 AM: npm ERR!   g++ '-DNODE_GYP_MODULE_NAME=binding' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DBUILDING_NODE_EXTENSION' -I/opt/buildhome/.node-gyp/16.16.0/include/node -I/opt/buildhome/.node-gyp/16.16.0/src -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/config -I/opt/buildhome/.node-gyp/16.16.0/deps/openssl/openssl/include -I/opt/buildhome/.node-gyp/16.16.0/deps/uv/include -I/opt/buildhome/.node-gyp/16.16.0/deps/zlib -I/opt/buildhome/.node-gyp/16.16.0/deps/v8/include -I../../nan -I../src/libsass/include  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -fno-rtti -fno-exceptions -std=gnu++14 -std=c++0x -MMD -MF ./Release/.deps/Release/obj.target/binding/src/binding.o.d.raw   -c -o Release/obj.target/binding/src/binding.o ../src/binding.cpp
11:37:32 AM: npm ERR! make: Leaving directory '/opt/build/repo/node_modules/node-sass/build'
11:37:32 AM: npm ERR! gyp info it worked if it ends with ok
11:37:32 AM: npm ERR! gyp verb cli [
11:37:32 AM: npm ERR! gyp verb cli   '/opt/buildhome/.nvm/versions/node/v16.16.0/bin/node',
11:37:32 AM: npm ERR! gyp verb cli   '/opt/build/repo/node_modules/node-gyp/bin/node-gyp.js',
11:37:32 AM: npm ERR! gyp verb cli   'rebuild',
11:37:32 AM: npm ERR! gyp verb cli   '--verbose',
11:37:32 AM: npm ERR! gyp verb cli   '--libsass_ext=',
11:37:32 AM: npm ERR! gyp verb cli   '--libsass_cflags=',
11:37:32 AM: npm ERR! gyp verb cli   '--libsass_ldflags=',
11:37:32 AM: npm ERR! gyp verb cli   '--libsass_library='
11:37:32 AM: npm ERR! gyp verb cli ]
11:37:32 AM: npm ERR! gyp info using node-gyp@3.8.0
11:37:32 AM: npm ERR! gyp info using node@16.16.0 | linux | x64
11:37:32 AM: npm ERR! gyp verb command rebuild []
11:37:32 AM: npm ERR! gyp verb command clean []
11:37:32 AM: npm ERR! gyp verb clean removing "build" directory
11:37:32 AM: npm ERR! gyp verb command configure []
11:37:32 AM: npm ERR! gyp verb check python checking for Python executable "python2" in the PATH
11:37:32 AM: npm ERR! gyp verb `which` succeeded python2 /opt/buildhome/python2.7/bin/python2
11:37:32 AM: npm ERR! gyp verb check python version `/opt/buildhome/python2.7/bin/python2 -c "import sys; print "2.7.18
npm ERR! gyp verb check python version .%s.%s" % sys.version_info[:3];"` returned: %j
11:37:32 AM: npm ERR! gyp verb get node dir no --target version specified, falling back to host node version: 16.16.0
11:37:32 AM: npm ERR! gyp verb command install [ '16.16.0' ]
11:37:32 AM: npm ERR! gyp verb install input version string "16.16.0"
11:37:32 AM: npm ERR! gyp verb install installing version: 16.16.0
11:37:32 AM: npm ERR! gyp verb install --ensure was passed, so won't reinstall if already installed
npm ERR! gyp verb install version not already installed, continuing with install 16.16.0
11:37:32 AM: npm ERR! gyp verb ensuring nodedir is created /opt/buildhome/.node-gyp/16.16.0
11:37:32 AM: npm ERR! gyp verb created nodedir /opt/buildhome/.node-gyp
11:37:32 AM: npm ERR! gyp http GET https://nodejs.org/download/release/v16.16.0/node-v16.16.0-headers.tar.gz
11:37:32 AM: npm ERR! gyp http 200 https://nodejs.org/download/release/v16.16.0/node-v16.16.0-headers.tar.gz
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/common.gypi
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/config.gypi
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/node.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/node_api.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/js_native_api.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/js_native_api_types.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/node_api_types.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/node_buffer.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/node_object_wrap.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/node_version.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/v8-platform.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/v8-version.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/v8-profiler.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/v8.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/v8config.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/v8-internal.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/libplatform/libplatform-export.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/libplatform/libplatform.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/libplatform/v8-tracing.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/cppgc/common.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/aix.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/android-ifaddrs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/bsd.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/darwin.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/linux.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/os390.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/posix.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/stdint-msvc2008.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/sunos.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/threadpool.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/errno.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/tree.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/unix.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/version.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/uv/win.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asn1err.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/obj_mac.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ripemd.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/rsa.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/seed.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/crypto.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/aes.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pem.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pemerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pkcs7.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pkcs7err.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/rand.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/rand_drbg.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/randerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/rc2.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/rc5.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/rsaerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ssl2.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ssl3.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/stack.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/store.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/tserr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ui.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509_vfy.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509err.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509v3.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/evp.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cmac.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cms.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ecdsa.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ocsperr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/err_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pkcs12err.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/rc4.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/safestack.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/whrlpool.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/opensslv.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/kdf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/kdferr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/md4.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/md5.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/mdc2.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/modes.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/objects.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pem2.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pkcs12.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/storeerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/symhacks.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ts.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/txt_db.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/uierr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/async.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/blowfish.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/camellia.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cast.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cmserr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/comp.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/comperr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/conf_api.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/conferr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cryptoerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ct.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cterr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/dh.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/dherr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/dsa.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/dsaerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/dtls1.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ebcdic.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ec.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ecdh.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asn1_mac.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asn1t.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ecerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/engine.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/engineerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/err.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/evperr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/hmac.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/lhash.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/md2.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/objectserr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ocsp.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509v3err.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ossl_typ.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ssl.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/sha.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/srp.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/srtp.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/sslerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/tls1.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asn1.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asyncerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bio.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bioerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bn.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bnerr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/buffer.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/buffererr.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/des.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/e_os2.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/idea.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/BSD-x86_64/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN32/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64-ARM/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64-ARM/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64-ARM/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64-ARM/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64-ARM/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/VC-WIN64A/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix-gcc/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/aix64-gcc/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin-i386-cc/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-arm64-cc/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/darwin64-x86_64-cc/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-aarch64/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-armv4/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-elf/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-ppc64le/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x86_64/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux32-s390x/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-mips64/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-s390x/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris-x86-gcc/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm_avx2/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm_avx2/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm_avx2/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/solaris64-x86_64-gcc/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x32/asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x32/asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x32/asm_avx2/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x32/asm_avx2/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x32/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux-x32/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-riscv64/no-asm/crypto/include/internal/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-riscv64/no-asm/crypto/include/internal/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-riscv64/no-asm/crypto/buildinf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-riscv64/no-asm/include/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/archs/linux64-riscv64/no-asm/include/progs.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/safestack_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bn_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/dso_conf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/opensslconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bio_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cmp_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cms_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/configuration_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ct_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ess_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/lhash_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/opensslv_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pkcs7_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ssl_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509v3_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509v3_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/crypto_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/fipskey_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/opensslconf_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pkcs7_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/srp_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asn1_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asn1t_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bio_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bn_conf_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cmp_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/conf_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/crmf_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/dso_conf_no-asm.h
11:37:32 AM: npm ERR! gyp verb content checksum node-v16.16.0-headers.tar.gz 89373d20e381b7f1ddd773f7e9c5bd3795876c0eab09696f7fc233c5d8db2e85
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/lhash_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ocsp_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pkcs12_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/srp_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ui_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/conf_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/crmf_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ct_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/err_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ess_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ocsp_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/opensslv_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/safestack_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ui_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509_vfy_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asn1_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/asn1t_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/bn_conf_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/cms_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/configuration_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/crypto_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/dso_conf_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/fipskey_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/opensslconf_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/pkcs12_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/ssl_asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/openssl/x509_vfy_no-asm.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/zconf.h
11:37:32 AM: npm ERR! gyp verb extracted file from tarball include/node/zlib.h
11:37:32 AM: npm ERR! gyp verb tarball done parsing tarball
11:37:32 AM: npm ERR! gyp verb check download content checksum, need to download `SHASUMS256.txt`...
11:37:32 AM: npm ERR! gyp verb checksum url https://nodejs.org/download/release/v16.16.0/SHASUMS256.txt
11:37:32 AM: npm ERR! gyp http GET https://nodejs.org/download/release/v16.16.0/SHASUMS256.txt
11:37:32 AM: npm ERR! gyp http 200 https://nodejs.org/download/release/v16.16.0/SHASUMS256.txt
11:37:32 AM: npm ERR! gyp verb checksum data {"node-v16.16.0-aix-ppc64.tar.gz":"6050ce2c71ef0acca9bc09a0dbbc19b243d1915839b3a349f08ac92672c09ff7","node-v16.16.0-darwin-arm64.tar.gz":"167721c2d72402e54adc0f8c87ca840796216c4d98946509d73221b771ad3e4c","node-v16.16.0-darwin-arm64.tar.xz":"e4468368bf25ee1c504f08ecfd0d9fec17a9e72ef27c4495406b958cd7b4bafd","node-v16.16.0-darwin-x64.tar.gz":"982edd0fad364ad6e2d72161671544ab9399bd0ca8c726bde3cd07775c4c709a","node-v16.16.0-darwin-x64.tar.xz":"a65b2b92ede6be9004eae1ca9da26da2178bc696f35e8cca1840c33b777a5421","node-v16.16.0-headers.tar.gz":"89373d20e381b7f1ddd773f7e9c5bd3795876c0eab09696f7fc233c5d8db2e85","node-v16.16.0-headers.tar.xz":"d463bae761d7fde776564d25012190df1e2b85e2b93480eaf413126331973fbc","node-v16.16.0-linux-arm64.tar.gz":"378a3998e7c4dabd0cbd96b05a1b08e834c4b607f09c0745072de9423626fca4","node-v16.16.0-linux-arm64.tar.xz":"6cb8f1353480646c1cd8ab9911995e5591e1a97811f43ea4ab3e946a57e7c80e","node-v16.16.0-linux-armv7l.tar.gz":"cd061554c3a9f1bac0a0bcafbbf50e10c9e5f6efbf98ee3450bb0920194ec06d","node-v16.16.0-linux-armv7l.tar.xz":"b8f499e38792e7b24d38da4169ab999cbbdfbf597ef86447aeaa661679ef0604","node-v16.16.0-linux-ppc64le.tar.gz":"3f1c57af5994e4f524d33e0173e5b60a76ad2347bc4b838719bc06cc0a1ef1c3","node-v16.16.0-linux-ppc64le.tar.xz":"32c665437a17cb5ad273ed7abe1a5711935f2b86d36dce315b5655d524fbc041","node-v16.16.0-linux-s390x.tar.gz":"b71b5dd31f398c5467cc3b93a79d5757e7ad286e5ad2bd79d5fda6b775b481c7","node-v16.16.0-linux-s390x.tar.xz":"bd779749163d3b26d2b54fc6f9731fd6dba903c7b54caa40afbbb9476637cdff","node-v16.16.0-linux-x64.tar.gz":"c85b16d1a4c259d01be7111ecb0361260627e4fc245004a920521eacb28e50df","node-v16.16.0-linux-x64.tar.xz":"edcb6e9bb049ae365611aa209fc03c4bfc7e0295dbcc5b2f1e710ac70384a8ec","node-v16.16.0.pkg":"ee42133ad6de3cd61954c2abf4a03d123f9e596d2f658247c59b8ad43fd2f147","node-v16.16.0.tar.gz":"e07c30b0498f143c08793e34bda1adeaad32f485a4f79f4d67a82879f4c0bbe3","node-v16.16.0.tar.xz":"145151eff3b2aa5ebe73384009c52271a83740ae687a93c98c628cd7d52736eb","node-v16.16.0-win-x64.7z":"cfe9ba47f32dd2c667078ed175e76cad1d00bd4ea9f915219ead81d2cfca3c34","node-v16.16.0-win-x64.zip":"c657acc98af55018c8fd6113c7e08d67c8083af75ba0306f9561b0117abc39d4","node-v16.16.0-win-x86.7z":"a933c0f78bc653dfba11df49c476e90e7ed2492f34319d74bf7de2b21f8943d8","node-v16.16.0-win-x86.zip":"957783527844fcd7da1d0b6dd311b64f92e2c5185112ada2d92e52c1a71fb373","node-v16.16.0-x64.msi":"c94f794d56ab6b5ba817a7a2efcc3ea9e81893126f6a925963542aa8ad34f798","node-v16.16.0-x86.msi":"1117bbde79025da055c87d35aa230f3c9a8855bf8e92bd126c30ec51b8dc8afd","win-x64/node.exe":"a7da2a7db76991bbb6a058b034969d2464cbd1b4c9af35c39def8a79cbbb01cc","win-x64/node.lib":"a676e936f019206ecfb19a878802c085841ac34f8f83080d4261e5ca138b011c","win-x64/node_pdb.7z":"811b52184ff4c7e104ac752088c2dae6fcd91d22e4d0361809e6d66fa4d68575","win-x64/node_pdb.zip":"595b784a4fdd1c682a020c2f5742ab302abb018ca28e25db46666e0061b2f7f5","win-x86/node.exe":"b928c03c1985e8fa1664fc2e795daecac612b0a8a75491f72ccbc09f5a9c65e6","win-x86/node.lib":"8574cc9643d304df424d038f37b2a78cc3c2a7dd58c2f1b9ff5d9a07da73d80d","win-x86/node_pdb.7z":"bd79146dfe7984b82d32b69985bde595c30c86bbbd1c6fe7620381872c3006e1","win-x86/node_pdb.zip":"a004a56c407d1f35e91141a5b86981a2d1cc1049a5f4092a6bde562076135d88"}
11:37:32 AM: npm ERR! gyp verb download contents checksum {"node-v16.16.0-headers.tar.gz":"89373d20e381b7f1ddd773f7e9c5bd3795876c0eab09696f7fc233c5d8db2e85"}
11:37:32 AM: npm ERR! gyp verb validating download checksum for node-v16.16.0-headers.tar.gz (89373d20e381b7f1ddd773f7e9c5bd3795876c0eab09696f7fc233c5d8db2e85 == 89373d20e381b7f1ddd773f7e9c5bd3795876c0eab09696f7fc233c5d8db2e85)
11:37:32 AM: npm ERR! gyp verb get node dir target node version installed: 16.16.0
11:37:32 AM: npm ERR! gyp verb build dir attempting to create "build" dir: /opt/build/repo/node_modules/node-sass/build
11:37:32 AM: npm ERR! gyp verb build dir "build" dir needed to be created? /opt/build/repo/node_modules/node-sass/build
11:37:32 AM: npm ERR! gyp verb build/config.gypi creating config file
11:37:32 AM: npm ERR! gyp verb build/config.gypi writing out config file: /opt/build/repo/node_modules/node-sass/build/config.gypi
11:37:32 AM: npm ERR! (node:1410) [DEP0150] DeprecationWarning: Setting process.config is deprecated. In the future the property will be read-only.
11:37:32 AM: npm ERR! (Use `node --trace-deprecation ...` to show where the warning was created)
11:37:32 AM: npm ERR! gyp verb config.gypi checking for gypi file: /opt/build/repo/node_modules/node-sass/config.gypi
11:37:32 AM: npm ERR! gyp verb common.gypi checking for gypi file: /opt/build/repo/node_modules/node-sass/common.gypi
11:37:32 AM: npm ERR! gyp verb gyp gyp format was not specified; forcing "make"
11:37:32 AM: npm ERR! gyp info spawn /opt/buildhome/python2.7/bin/python2
11:37:32 AM: npm ERR! gyp info spawn args [
11:37:32 AM: npm ERR! gyp info spawn args   '/opt/build/repo/node_modules/node-gyp/gyp/gyp_main.py',
11:37:32 AM: npm ERR! gyp info spawn args   'binding.gyp',
11:37:32 AM: npm ERR! gyp info spawn args   '-f',
11:37:32 AM: npm ERR! gyp info spawn args   'make',
11:37:32 AM: npm ERR! gyp info spawn args   '-I',
11:37:32 AM: npm ERR! gyp info spawn args   '/opt/build/repo/node_modules/node-sass/build/config.gypi',
11:37:32 AM: npm ERR! gyp info spawn args   '/opt/build/repo/node_modules/node-gyp/addon.gypi',
11:37:32 AM: npm ERR! gyp info spawn args   '/opt/buildhome/.node-gyp/16.16.0/include/node/common.gypi',
11:37:32 AM: npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
11:37:32 AM: npm ERR! gyp info spawn args   '-Dvisibility=default',
11:37:32 AM: npm ERR! gyp info spawn args   '-Dnode_root_dir=/opt/buildhome/.node-gyp/16.16.0',
11:37:32 AM: npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/opt/build/repo/node_modules/node-gyp',
11:37:32 AM: npm ERR! gyp info spawn args   '-Dnode_lib_file=/opt/buildhome/.node-gyp/16.16.0/<(target_arch)/node.lib',
11:37:32 AM: npm ERR! gyp info spawn args   '-Dmodule_root_dir=/opt/build/repo/node_modules/node-sass',
11:37:32 AM: npm ERR! gyp info spawn args   '-Dnode_engine=v8',
11:37:32 AM: npm ERR! gyp info spawn args   '--depth=.',
11:37:32 AM: npm ERR! gyp info spawn args   '--no-parallel',
11:37:32 AM: npm ERR! gyp info spawn args   '--generator-output',
11:37:32 AM: npm ERR! gyp info spawn args   'build',
11:37:32 AM: npm ERR! gyp info spawn args   '-Goutput_dir=.'
11:37:32 AM: npm ERR! gyp info spawn args ]
11:37:32 AM: npm ERR! gyp verb command build []
11:37:32 AM: npm ERR! gyp verb build type Release
11:37:32 AM: npm ERR! gyp verb architecture x64
11:37:32 AM: npm ERR! gyp verb node dev dir /opt/buildhome/.node-gyp/16.16.0
11:37:32 AM: npm ERR! gyp verb `which` succeeded for `make` /usr/bin/make
11:37:32 AM: npm ERR! gyp info spawn make
11:37:32 AM: npm ERR! gyp info spawn args [ 'V=1', 'BUILDTYPE=Release', '-C', 'build' ]
11:37:32 AM: npm ERR! ../src/libsass/src/cencode.c: In function ‘base64_encode_block’:
11:37:32 AM: npm ERR! ../src/libsass/src/cencode.c:48:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
11:37:32 AM: npm ERR!    48 |    result = (fragment & 0x003) << 4;
11:37:32 AM: npm ERR!       |    ~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~
11:37:32 AM: npm ERR! ../src/libsass/src/cencode.c:52:2: note: here
11:37:32 AM: npm ERR!    52 |  case step_B:
11:37:32 AM: npm ERR!       |  ^~~~
11:37:32 AM: npm ERR! ../src/libsass/src/cencode.c:62:11: warning: this statement may fall through [-Wimplicit-fallthrough=]
11:37:32 AM: npm ERR!    62 |    result = (fragment & 0x00f) << 2;
11:37:32 AM: npm ERR! ../src/libsass/src/cencode.c:66:2: note: here
11:37:32 AM: npm ERR!    66 |  case step_C:
11:37:32 AM: npm ERR! ../src/libsass/src/functions.cpp: In function ‘void Sass::Functions::handle_utf8_error(const Sass::ParserState&, Sass::Backtraces)’:
11:37:32 AM: npm ERR! ../src/libsass/src/functions.cpp:110:20: warning: catching polymorphic type ‘class utf8::invalid_code_point’ by value [-Wcatch-value=]
11:37:32 AM: npm ERR!   110 |       catch (utf8::invalid_code_point) {
11:37:32 AM: npm ERR!       |                    ^~~~~~~~~~~~~~~~~~
11:37:32 AM: npm ERR! ../src/libsass/src/functions.cpp:114:20: warning: catching polymorphic type ‘class utf8::not_enough_room’ by value [-Wcatch-value=]
11:37:32 AM: npm ERR!   114 |       catch (utf8::not_enough_room) {
11:37:32 AM: npm ERR! ../src/libsass/src/functions.cpp:118:20: warning: catching polymorphic type ‘class utf8::invalid_utf8’ by value [-Wcatch-value=]
11:37:32 AM: npm ERR!   118 |       catch (utf8::invalid_utf8) {
11:37:32 AM: npm ERR! ../src/libsass/src/json.cpp: In function ‘char* json_encode_string(const char*)’:
11:37:32 AM: npm ERR! ../src/libsass/src/json.cpp:405:15: warning: catching polymorphic type ‘class std::exception’ by value [-Wcatch-value=]
11:37:32 AM: npm ERR!   405 |   catch (std::exception) {
11:37:32 AM: npm ERR! ../src/libsass/src/json.cpp: In function ‘char* json_stringify(const JsonNode*, const char*)’:
11:37:32 AM: npm ERR! ../src/libsass/src/json.cpp:424:15: warning: catching polymorphic type ‘class std::exception’ by value [-Wcatch-value=]
11:37:32 AM: npm ERR!   424 |   catch (std::exception) {
11:37:32 AM: npm ERR! In file included from /opt/buildhome/.node-gyp/16.16.0/include/node/v8.h:30,
11:37:32 AM: npm ERR!                  from /opt/buildhome/.node-gyp/16.16.0/include/node/node.h:63,
11:37:32 AM: npm ERR!                  from ../../nan/nan.h:60,
11:37:32 AM: npm ERR!                  from ../src/binding.cpp:1:
11:37:32 AM: npm ERR! /opt/buildhome/.node-gyp/16.16.0/include/node/v8-internal.h: In function ‘void v8::internal::PerformCastCheck(T*)’:
11:37:32 AM: npm ERR! /opt/buildhome/.node-gyp/16.16.0/include/node/v8-internal.h:492:38: error: ‘remove_cv_t’ is not a member of ‘std’; did you mean ‘remove_cv’?
11:37:32 AM: npm ERR!   492 |             !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
11:37:32 AM: npm ERR!       |                                      remove_cv
11:37:32 AM: npm ERR! /opt/buildhome/.node-gyp/16.16.0/include/node/v8-internal.h:492:50: error: template argument 2 is invalid
11:37:32 AM: npm ERR! /opt/buildhome/.node-gyp/16.16.0/include/node/v8-internal.h:492:63: error: ‘::Perform’ has not been declared
11:37:32 AM: npm ERR! ../src/binding.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE render(Nan::NAN_METHOD_ARGS_TYPE)’:
11:37:32 AM: npm ERR! ../src/binding.cpp:284:98: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
11:37:32 AM: npm ERR!   284 |     int status = uv_queue_work(uv_default_loop(), &ctx_w->request, compile_it, (uv_after_work_cb)MakeCallback);
11:37:32 AM: npm ERR! ../src/binding.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE render_file(Nan::NAN_METHOD_ARGS_TYPE)’:
11:37:32 AM: npm ERR! ../src/binding.cpp:320:98: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
11:37:32 AM: npm ERR!   320 |     int status = uv_queue_work(uv_default_loop(), &ctx_w->request, compile_it, (uv_after_work_cb)MakeCallback);
11:37:32 AM: npm ERR! In file included from ../../nan/nan.h:60,
11:37:32 AM: npm ERR! ../src/binding.cpp: At global scope:
11:37:32 AM: npm ERR! /opt/buildhome/.node-gyp/16.16.0/include/node/node.h:847:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
11:37:32 AM: npm ERR!   847 |       (node::addon_register_func) (regfunc),                          \
11:37:32 AM: npm ERR! /opt/buildhome/.node-gyp/16.16.0/include/node/node.h:881:3: note: in expansion of macro ‘NODE_MODULE_X’
11:37:32 AM: npm ERR!   881 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
11:37:32 AM: npm ERR! ../src/binding.cpp:358:1: note: in expansion of macro ‘NODE_MODULE’
11:37:32 AM: npm ERR!   358 | NODE_MODULE(binding, RegisterModule);
11:37:32 AM: npm ERR! make: *** [binding.target.mk:133: Release/obj.target/binding/src/binding.o] Error 1
11:37:32 AM: npm ERR! gyp ERR! build error
11:37:32 AM: npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
11:37:32 AM: npm ERR! gyp ERR! stack     at ChildProcess.onExit (/opt/build/repo/node_modules/node-gyp/lib/build.js:262:23)
11:37:32 AM: npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:527:28)
11:37:32 AM: npm ERR! gyp ERR! stack     at Process.ChildProcess._handle.onexit (node:internal/child_process:291:12)
11:37:32 AM: npm ERR! gyp ERR! System Linux 5.4.181-99.354.amzn2.x86_64
11:37:32 AM: npm ERR! gyp ERR! command "/opt/buildhome/.nvm/versions/node/v16.16.0/bin/node" "/opt/build/repo/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libsass_cflags=" "--libsass_ldflags=" "--libsass_library="
11:37:32 AM: npm ERR! gyp ERR! cwd /opt/build/repo/node_modules/node-sass
11:37:32 AM: npm ERR! gyp ERR! node -v v16.16.0
11:37:32 AM: npm ERR! gyp ERR! node-gyp -v v3.8.0
11:37:32 AM: npm ERR! gyp ERR! not ok
11:37:32 AM: npm ERR! Build failed with error code: 1
11:37:32 AM: npm ERR! A complete log of this run can be found in:
11:37:32 AM: npm ERR!     /opt/buildhome/.npm/_logs/2022-07-11T03_34_33_305Z-debug-0.log
11:37:32 AM: Error during NPM install
11:37:32 AM: Build was terminated: Build script returned non-zero exit code: 1
11:37:33 AM: Creating deploy upload records
11:37:33 AM: Failing build: Failed to build site
11:37:33 AM: Failed during stage 'building site': Build script returned non-zero exit code: 1 (https://ntl.fyi/exit-code-1)
11:37:33 AM: Finished processing build request in 3m10.161805882s
Hey @angelangweihan , have you been able to successfully build your site locally?
This Support Guide contains a ton of useful debugging tips that can likely help you solve your problem :slight_smile: Additionally, this Support Guide houses all of our resources for debugging build and deploy issues.
We also recommend trying to search the forums with the build error you encountered - it’s likely your question was already asked by someone else!
If you are still having problems, please provide a link to the deploy log from the Netlify UI and provide as much information as you can on what you have already tried, and we can work from there!
