I canβt build a site from github, but when I build locally and upload the folder manually, works fine. Here are my logs. Thanks for your help.
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/sass_functions.o ../src/libsass/src/sass_functions.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass_functions.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/sass_util.o ../src/libsass/src/sass_util.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass_util.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/sass_values.o ../src/libsass/src/sass_values.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/sass_values.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/source_map.o ../src/libsass/src/source_map.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/source_map.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/subset_map.o ../src/libsass/src/subset_map.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/subset_map.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/to_c.o ../src/libsass/src/to_c.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/to_c.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/to_value.o ../src/libsass/src/to_value.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/to_value.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/units.o ../src/libsass/src/units.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/units.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/utf8_string.o ../src/libsass/src/utf8_string.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/utf8_string.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/util.o ../src/libsass/src/util.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/util.o.d.raw -c
4:18:20 PM: g++ -o Release/obj.target/libsass/src/libsass/src/values.o ../src/libsass/src/values.cpp '-DNODE_GYP_MODULE_NAME=libsass' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DLIBSASS_VERSION="3.5.5"' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -std=gnu++14 -std=c++0x -fexceptions -frtti -MMD -MF ./Release/.deps/Release/obj.target/libsass/src/libsass/src/values.o.d.raw -c
4:18:20 PM: rm -f Release/obj.target/src/sass.a && ar crs Release/obj.target/src/sass.a Release/obj.target/libsass/src/libsass/src/ast.o Release/obj.target/libsass/src/libsass/src/ast_fwd_decl.o Release/obj.target/libsass/src/libsass/src/backtrace.o Release/obj.target/libsass/src/libsass/src/base64vlq.o Release/obj.target/libsass/src/libsass/src/bind.o Release/obj.target/libsass/src/libsass/src/cencode.o Release/obj.target/libsass/src/libsass/src/check_nesting.o Release/obj.target/libsass/src/libsass/src/color_maps.o Release/obj.target/libsass/src/libsass/src/constants.o Release/obj.target/libsass/src/libsass/src/context.o Release/obj.target/libsass/src/libsass/src/cssize.o Release/obj.target/libsass/src/libsass/src/emitter.o Release/obj.target/libsass/src/libsass/src/environment.o Release/obj.target/libsass/src/libsass/src/error_handling.o Release/obj.target/libsass/src/libsass/src/eval.o Release/obj.target/libsass/src/libsass/src/expand.o Release/obj.target/libsass/src/libsass/src/extend.o Release/obj.target/libsass/src/libsass/src/file.o Release/obj.target/libsass/src/libsass/src/functions.o Release/obj.target/libsass/src/libsass/src/inspect.o Release/obj.target/libsass/src/libsass/src/json.o Release/obj.target/libsass/src/libsass/src/lexer.o Release/obj.target/libsass/src/libsass/src/listize.o Release/obj.target/libsass/src/libsass/src/memory/SharedPtr.o Release/obj.target/libsass/src/libsass/src/node.o Release/obj.target/libsass/src/libsass/src/operators.o Release/obj.target/libsass/src/libsass/src/output.o Release/obj.target/libsass/src/libsass/src/parser.o Release/obj.target/libsass/src/libsass/src/plugins.o Release/obj.target/libsass/src/libsass/src/position.o Release/obj.target/libsass/src/libsass/src/prelexer.o Release/obj.target/libsass/src/libsass/src/remove_placeholders.o Release/obj.target/libsass/src/libsass/src/sass.o Release/obj.target/libsass/src/libsass/src/sass2scss.o Release/obj.target/libsass/src/libsass/src/sass_context.o Release/obj.target/libsass/src/libsass/src/sass_functions.o Release/obj.target/libsass/src/libsass/src/sass_util.o Release/obj.target/libsass/src/libsass/src/sass_values.o Release/obj.target/libsass/src/libsass/src/source_map.o Release/obj.target/libsass/src/libsass/src/subset_map.o Release/obj.target/libsass/src/libsass/src/to_c.o Release/obj.target/libsass/src/libsass/src/to_value.o Release/obj.target/libsass/src/libsass/src/units.o Release/obj.target/libsass/src/libsass/src/utf8_string.o Release/obj.target/libsass/src/libsass/src/util.o Release/obj.target/libsass/src/libsass/src/values.o
4:18:20 PM: ln -f "Release/obj.target/src/sass.a" "Release/sass.a" 2>/dev/null || (rm -rf "Release/sass.a" && cp -af "Release/obj.target/src/sass.a" "Release/sass.a")
4:18:20 PM: g++ -o Release/obj.target/binding/src/binding.o ../src/binding.cpp '-DNODE_GYP_MODULE_NAME=binding' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DBUILDING_NODE_EXTENSION' -I/opt/buildhome/.cache/node-gyp/16.7.0/include/node -I/opt/buildhome/.cache/node-gyp/16.7.0/src -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/config -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/openssl/openssl/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/uv/include -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/zlib -I/opt/buildhome/.cache/node-gyp/16.7.0/deps/v8/include -I../../nan -I../src/libsass/include -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -m64 -O3 -fno-omit-frame-pointer -fno-rtti -fno-exceptions -std=gnu++14 -std=c++0x -MMD -MF ./Release/.deps/Release/obj.target/binding/src/binding.o.d.raw -c
4:18:20 PM: In file included from /opt/buildhome/.cache/node-gyp/16.7.0/include/node/v8.h:30,
4:18:20 PM: from /opt/buildhome/.cache/node-gyp/16.7.0/include/node/node.h:63,
4:18:20 PM: from ../../nan/nan.h:56,
4:18:20 PM: from ../src/binding.cpp:1:
4:18:20 PM: /opt/buildhome/.cache/node-gyp/16.7.0/include/node/v8-internal.h: In function βvoid v8::internal::PerformCastCheck(T*)β:
4:18:20 PM: /opt/buildhome/.cache/node-gyp/16.7.0/include/node/v8-internal.h:488:38: error: βremove_cv_tβ is not a member of βstdβ; did you mean βremove_cvβ?
4:18:20 PM: 488 | !std::is_same<Data, std::remove_cv_t<T>>::value>::Perform(data);
4:18:20 PM: | ^~~~~~~~~~~
4:18:20 PM: | remove_cv
4:18:20 PM: /opt/buildhome/.cache/node-gyp/16.7.0/include/node/v8-internal.h:488:50: error: template argument 2 is invalid
4:18:20 PM: | ^
4:18:20 PM: /opt/buildhome/.cache/node-gyp/16.7.0/include/node/v8-internal.h:488:63: error: β::Performβ has not been declared
4:18:20 PM: ../src/binding.cpp: In function βNan::NAN_METHOD_RETURN_TYPE render(Nan::NAN_METHOD_ARGS_TYPE)β:
4:18:20 PM: ../src/binding.cpp:284:98: warning: cast between incompatible function types from βvoid (*)(uv_work_t*)β {aka βvoid (*)(uv_work_s*)β} to βuv_after_work_cbβ {aka βvoid (*)(uv_work_s*, int)β} [-Wcast-function-type]
4:18:20 PM: 284 | int status = uv_queue_work(uv_default_loop(), &ctx_w->request, compile_it, (uv_after_work_cb)MakeCallback);
4:18:20 PM: | ^~~~~~~~~~~~
4:18:20 PM: ../src/binding.cpp: In function βNan::NAN_METHOD_RETURN_TYPE render_file(Nan::NAN_METHOD_ARGS_TYPE)β:
4:18:20 PM: ../src/binding.cpp:320:98: warning: cast between incompatible function types from βvoid (*)(uv_work_t*)β {aka βvoid (*)(uv_work_s*)β} to βuv_after_work_cbβ {aka βvoid (*)(uv_work_s*, int)β} [-Wcast-function-type]
4:18:20 PM: 320 | int status = uv_queue_work(uv_default_loop(), &ctx_w->request, compile_it, (uv_after_work_cb)MakeCallback);
4:18:20 PM: In file included from ../../nan/nan.h:56,
4:18:20 PM: ../src/binding.cpp: At global scope:
4:18:20 PM: /opt/buildhome/.cache/node-gyp/16.7.0/include/node/node.h:806:43: warning: cast between incompatible function types from βvoid (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)β {aka βvoid (*)(v8::Local<v8::Object>)β} to βnode::addon_register_funcβ {aka βvoid (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)β} [-Wcast-function-type]
4:18:20 PM: 806 | (node::addon_register_func) (regfunc), \
4:18:20 PM: | ^
4:18:20 PM: /opt/buildhome/.cache/node-gyp/16.7.0/include/node/node.h:840:3: note: in expansion of macro βNODE_MODULE_Xβ
4:18:20 PM: 840 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)
4:18:20 PM: | ^~~~~~~~~~~~~
4:18:20 PM: ../src/binding.cpp:358:1: note: in expansion of macro βNODE_MODULEβ
4:18:20 PM: 358 | NODE_MODULE(binding, RegisterModule);
4:18:20 PM: make: *** [binding.target.mk:133: Release/obj.target/binding/src/binding.o] Error 1
4:18:20 PM: make: Leaving directory '/opt/build/repo/node_modules/node-sass/build'
4:18:20 PM: gyp ERR! build error
4:18:20 PM: gyp ERR! stack Error: `make` failed with exit code: 2
4:18:20 PM: gyp ERR! stack at ChildProcess.onExit (/opt/build/repo/node_modules/node-gyp/lib/build.js:194:23)
4:18:20 PM: gyp ERR! stack at ChildProcess.emit (node:events:394:28)
4:18:20 PM: gyp ERR! stack at Process.ChildProcess._handle.onexit (node:internal/child_process:290:12)
4:18:20 PM: gyp ERR! System Linux 4.19.167+
4:18:20 PM: gyp ERR! command "/opt/buildhome/.nvm/versions/node/v16.7.0/bin/node" "/opt/build/repo/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libsass_cflags=" "--libsass_ldflags=" "--libsass_library="
4:18:20 PM: gyp ERR! cwd /opt/build/repo/node_modules/node-sass
4:18:20 PM: gyp ERR! node -v v16.7.0
4:18:20 PM: gyp ERR! node-gyp -v v7.1.2
4:18:20 PM: gyp ERR! not ok
4:18:20 PM: Build failed with error code: 1
4:18:20 PM: Error during Yarn install
4:18:20 PM: Build was terminated: Build script returned non-zero exit code: 1
4:18:21 PM: Failing build: Failed to build site
4:18:21 PM: Finished processing build request in 3m20.011480094s
